Sway bar upgrade done
Nyparrothead
Hi all, well I awoke to 8in of snow today I set my ramps on the tailgate of my truck and pulled the F3 up on them to get the clearance needed. When I took off the two plastic pieces on the bottom there was a torn head screw inside one of them. I wonder where the factory left it out from?
anyway, I removed the old one and got the new one in... Getting the new blocks in was A PAIN IN THE A$$! Got it all together but I found I had to push one side of the bar up to get the bolt in, should it be under tension? I don't think the old one was....
what do you think
Mark
I just did the bar on my 2014 RTL. Blocks didn't want to go into the channel. Found a quick easy way to solve that. A small C- clamp to squeeze then together and they slide in with no problem. As far as the bar not wanting to hook up to the links, my guess is that the ride height on one shock is higher than the other causing it to lean just a bit.
