AY4B
Hoping to read that it turned out well for you! Just had a Sport Touring delivered for my RT LTD with plans to install it myself. Which brings me to the question of. Any luck with the repair? Was it an easy install for you? Any special tools needed beside a torque wrench? Why did you need to cut the bolts off and which one s were they? What if any would you do different next time?
I cleaned up my repair last night, It looks a lot better than the pic I posted. I do not regret doing the install myself. Dropping the silencer was just one of those things that would never happen again in a million years. I would take it to the muffler guy today but we are having severe storms all this weekend in N Texas. The bolts I cut were the 2 bolts that fasten the muffler to the Cat Converter. They have one side with an allen screw and the other with a nut, washer and spring and little space for a socket wrench. The Threads looked to be intentionally damaged or something so that even after breaking the first few turns, It seemed to not want to turn without breaking the allen wrench. I have a set of allen sockets that are even stronger and it was extremely Hard to turn, I kind of felt like the nut wa cross threaded in there only the problem was with both of them. The directions say those bolts will be trashed anyway and they provide new bolts, washers and nuts. I used up a cut off tool blade for one side and the other side, I used a reciprocating saw. It was getting late and I was so exited about getting it on, I was tired and got careless. The directions are all large black and white photos that take you one step at a time. Dont miss the part at the end where it says to run the spyder at Idle for 15 minutes and then let it sit for 30. It is a essential break in step. I did not use a torque wrench, I have 2 of them, and the one that clicks was the only one I could get in there. It never clicked and I turned it till the flange started to deform some so I left it there. The main thing is the silencer needs to line up with the tire, straight up and down. The directions clearly point that out. The only way I could get it straight like that was to tighten the outside nut a lt more than the inside nut. Other than that there are no special tools needed. I think that on the RT there may be an extra bolt, but not sure. On my Install there were a total of 3 bolts in all. The one on the side was a piece of cake.
Bill
PS You ill need to either jack up your spyder or put it up on ramps.
