This might help with your Pedalbox or Pedal Commander install on a 2025 RT
jagr
The Throttle harness has been moved from the right side (on 2024's) to the left side for 2025 RT's. It is now under the left front speakers on top of the blower motor housing. You will need to remove the left side panels and look up for it from a very low position (I sat on the floor) with a flashlight to find it. I hope this helps you have less frustration than I did while trying to find it, because the 2024+ installation videos show it on the right side.
You're welcome 😁
According to a response I received to this question on CanAmSpyderForums: “found the connector under the RIGHT lower speaker housing remove the grill and it's down in there. I will post a picture. to get to it I had to remove the 3 panels on the right side and come from underneath. the problem is that CanAm has changed connectors and it looks more like what was used on the 2023. Pedal commander is now studying the problem and will let me know if the wiring is the same."
Is it possible that there were two different setups on the 2025’s?
If it's a Can Am Spyder, then the answer to that ^ question is a resounding "YES!" 😣
Oh, and there's also a good chance that neither the Owner's Manual nor any wiring diagram will truly reflect any version of what's actually there on said 2025's - the manual/wiring diagrams as published by BRP could well contain info/diagrams that've been cut & pasted from a completely different model, like maybe a 2013 RSS or maybe a 2015 F3! 😖
Just Sayin' 🤨
