Not a tire for the Spyder but it is Science
First, as a newbie, I find this whole conversation funny as heck. Both sides convinced they are on the correct side.
I will be the first to admit I have not done any testing nor have I been to any school, however, I have done a lot of related research.
My other 2 vehicles are a Ram 2500 and a Jeep Wrangler. This is mentioned because I run non standard tires on both and have had to determine the correct tire pressures to run. The federally mandated placard does not apply to my scenario.
I assume (I know what that means) that the tire manufactures have the very elusive science everybody seems to be interested in.
The following links have been helpful in helping me to determine what tire pressures to run in the TOYO tires I run on the Ram and Jeep based on the loads I expect the tires to carry.
https://www.toyotires.com/tires-101/tire-load-and-inflation-tables
This is a link to the rather long PDF showing different pressures for the same tires based on loads they expect the tire to carry.
https://www.toyotires.com/media/2125/application_of_load_inflation_tables_20170203.pdf
I don't know how this fits into this discussion specifically except that many people have mentioned science and facts and I think this is about as close as an example we are going to find for determining proper pressures. As I said, these don't pertain to the tires in question. A person would have to find similar data from the manufacture for the tire they intend to use.
It would appear to me that without the correct load-inflation table for the specific tire you are planning on mounting AND an accurate weight/load for the tire/axle in question, you are just guessing on the correct pressure.
If I am totally off base here, chalk it up to being a newbie...
