Today I tried navigation via BRP Go (2024+)...
It's a USB 2.0 port, which by definition is 5V and 500mA.
I'm sure at 500ma my phone would've lost charge while navigating with the display screen on for over 2 hours, yet it kept the charge at 80%.
If it's a USB 2.0, then 0.5A is the standard for computers (launched more than 25 years ago), but it has been revised for chargers to support charging larger batteries. In fact, I believe you can deliver whatever you need as long it's 5V, cable and whatever is in the other end will dictate the current pulled.
Google thinks the USB 2.0 standard has not changed.
I did find one reference to a change to an embedded USB 2.0 (eUSB2V2) dated 09/27/2024 that is described as:
This eUSB2 Version 2.0 (eUSB2V2) document defines a performance enhancement to the USB industry-standard, USB 2.0 and eUSB2 specifications. The USB 2.0 specification describes the protocol definition, types of transactions, and bus management required to design and build systems and peripherals that are compliant with this specification. eUSB2V2 is primarily a performance enhancement to eUSB2 native mode to provide more bandwidth for peripherals, such as embedded cameras, by adding significantly higher data rates to USB 2.0, while maintaining a low-voltage electrical interface.
So the data transfer rate was increased, but not the power.
Most USB 2.0, or 2.1 for that matter, devices as found in a computer on a chip, or low cost USB specific chips, tend to have effective data rates way below that of the rated specification.
I expect the data rate on the 10.25" cluster in no doubt quick enough to run Apply CarPlay apps and that's about it. Even if the hardware could go closer to the specification, the software overhead makes the effective data rate much lower.
That's my experience with systems resembling the capabilities of the Spyder's embedded display system.
When I bought my Spyder CAN-AM was still trying to get Apple Carplay to work correctly.
Once they released the software update, I immediately downloaded and installed it on my Spyder using my home WiFi network.
And then the issues started.
I am an Apple FanBoy, and had an iPhone SE at the time, which used the infamous Lightning connector.
So I tried to get my iPhone to connect.
Didn't work.
Went digging through my stuff and found a few more Apple Lightning cables, and started trying them.
I think I ended up testing 7 or 8 different Apple Lightning cables. If I remember correctly I found one that always worked, and one that worked most of the time. The other cables I tossed.
I now have an iPhone SE 2nd Gen, which uses a USB C cable. I'm using a braided Belkin cable USB C on my Spyder, and a 6" cheap no-name braided cable USB C cable in my Honda Ridgeline, which also supports Apple Carplay.
So the quality of the cable is important. Also, some manufacturers differentiate between data cables and charging cables. You need a "data" cable.
As for planning and saving trips, Google found this as the first step:
  • Open the RIDES icon/tab in the app and select CREATE ITINERARY.
So apparently you can create (and save?) an Itinerary for later use.
After BRP kept telling me to use a USB cable with having the phone bluetooth off never worked, I experimented on my own and discovered that when bluetooth is turned on and connected to the Spyder with the headset paired to the Spyder, it will connect every time. After they are connected, I plug in the USB cable and Apple CarPlay works every time.
Well, I'll say it again, I'm convinced there's no way my phone would have kept the state of charge during that +2h trip at 0.5A... So, I'm about sure charging power should be above 0.5A.
And power was actually increased to 1.5A with the introduction of BC1.2 (2010, 4 years before USB-C) to support battery charging.
Klein Tools ET 920 meter results for a 2024 Spyder RT Sea2Sky and iPhone SE 2nd Gen connected to the USB port in the glove box.
iPhone was connected to the meter using the same Belkin braided cable that I've been using for CarPlay on mySpyder.
The time in the lower left of the ET 920's screen is how long it had been connected.
I started the Spyder's engine before testing, and let it run for a few minutes to make sure the engine was warmed up and running at idle.
Connection: iPhone (USB C) --> Belkin Cable (USB C to USB A) --> ET 920 (USB A connections) --> Spyder front USB A port
(click for larger image)
Online ET 920 User Guide:
So from the instruction sheet I assume the 1.44 Amps is the negotiated power available as reported by the USB host, i.e. the Spyder's USB A connector? Or is it the actual instantaneous current draw, i.e. does that value move up and down over time?
The 57 mAh is the current draw from whatever you have plugged in to the meter?
So from that data your phone is drawing an average power consumption of 1.03 Amps over 200 seconds. I don't know if that's because it's the actual effective current draw limit, or that's just what your phone actually needs. I also can't tell peak consumption as it's averaged over 200 seconds?
Is this the correct understanding, or am I off base here?
If I'm not, it would be interesting to see if the Spyder can actually deliver 1.44 Amps peak?
I only understand what the manual says and since my professional background is computer software and not electrical engineering, I have no idea how to answer your question.
I did tell you what I had plugged into the device: an iPhone SE 2nd Gen.
The only thing I can say is that the numbers on the display appeared to be stable and not increasing over time.
If you like, I can run it again and post several pictures over a span of time?
If I understand the readings and my math is right:
00h 03mn 20s would be about 0.05556h of time
(https://www.inchcalculator.com/time-to-hours-calculator/)
0.297Wh in 0.05556h corresponds to an average of 5.4W of power
(https://convert-formula.com/wh-w)
So if this is true, the port managed to provide 5.4W, or roughly 1.1Ah at 5V.
This is over double of the USB2.0 standard, and that might explain why my mobile was able to charge while running BRP GO! app.
