Towing a spyder
prin
I am considering trailering my 2012 RT Limited for some trips that are substantially long. I know you are to tie down the spyder by using straps through the wheels, but have heard conflicting ideas about wheter the parking brake should be on or off. I have an alarm that goes off if I do not put my brake on when turning off the bike. Does towing with the brake on create too much stress on the brake? What is the best way? Any thoughts or ideas on towing (enclosed trailer) are appreciated. Thanks,
Ted
(prin)
Ted
(prin)
Set the brake thats what its for-sounds like a SE5
Doesn't matter what vehicle I am towing, Spyder, UTV, ATV, Snowmobile, Car, etc. If it is on a trailer I set the brake, if it has a brake to set.
Step #7 in the Owners Manual states to ENGAGE THE PARKING BRAKE
TRANSPORTING THE SPYDER ROADSTER​
If your vehicle needs to be transported,it should be carried on a flatbed trailerof the proper size and capacity.​
CAUTION​
If you need to pushthe vehicle, do it from the right-handside to be able to reach the brakepedal.When pulling the vehicle backwards,be careful that the frontwheel does not roll over your feet.
NOTICE​
Do not tow the Spyderroadster — towing can seriouslydamage the vehicle drive system.
When contacting a towing or transportingservice, be sure to ask if theyhave a flatbed trailer, loading ramp orpower ramp to safely lift the vehicleand tie-down straps. Ensure the vehicleis properly transported as specifiedin this section.​
NOTICE​
Avoid using chains to tiethe vehicle — they may damagethe surface finish or plastic components.
To load the vehicle for transport, proceedas follows:1. Shift the vehicle into NEUTRAL (N).2. Remove the key from the ignitionswitch.3. Put a strap around the lower arm ofeach front suspension.​
rmo2010-001-097_a​
1. Lower suspension arm2. Strap between shock absorber and fin​
NOTICE​
Do not place the strapover the fin. This could break it.
4. Attach the straps to thewinch cable.If possible, use chains or additionalstraps to attach the straps to thewinch cable as indicated below toavoid damaging the bumper cover.​
rmo2008-001-066_a​
TYPICAL​
1. Strap around front suspension lower arms2. Chains to avoid damaging the bumper cover3. Winch cable​
5. Ensure that the parking brake is released.6. Pull the vehicle on the flatbed trailerwith the winch.7. Engage the parking brake.8. Ensure that the vehicle gear is inNEUTRAL (N).9. Strap the front tires by using one thefollowing methods indicated below.​
110
Set the parking brake! You'll know why, if you ever have a strap break...:shocked:
The park brake only activates the rear brake. There's almost no weight on the ass end. In a trailer, it'll just barely slow it down from sliding around. Don't ask how I know:shocked:
Ted
(prin)
i have the spyder super clamps in my enclosed trailer. i know some don't care for them, but i love them. it takes me 2 minutes to load and strap down and literally 30 seconds to pull out of the trailer when unloading. in my eyes, you can't beat them. a little pricey, :yikes:but well worth the money! jmho!:thumbup: and yes, apply the parking brake!
