Travel Tool Kit
Arana
Does anyone out there know where I can get a travel tool kit for the:spyder2: I would appreciate directions.
The tool kit that comes with the Spyder is very good I just added a few tools to it that I felt would help based on working on the Spyder I will make a list when I get a chance and post it. From what I read you should also load in some relays there are several posts on this. Maybe someone who has made some long trips could suggest a few things. Oh and don't forget the duct tape. ;)
I added a small fire exstwher in trunk going to put hose 's in my engin compartment so when or if I get one I pull a ring and it floods my engin on my spyder like gasstations ingulfs the fire with powder .....
Does anyone have a good option for a cheap torq wrench with the bits necessary for our bike? I have one that I use in my garage but a small travel one would be nice in case I have to fiddle with the panels or something like that...
If you mean a true adjustable torque wrench, this one is cheap:
"BikeMaster Adjustable Micrometer Torque Wrench" with micrometer type sleeve Reversible ratchet head Hard plastic storage case included 3/8” Sq. Dr. marked range (5-80 Ft. Lbs)
But I think is better to carry just a regular ratchet for emergencies and re-adjust to the exact torque once you are back home or in a shop
For the bits is cheaper to buy the few you need off the rack but some times there are cheap metric sets on sale and you could just carry the bits the Spyder uses. My 2 cents...
3WD
