bikerchris1270
Has anyone just lifted/removed the front tire(s) and did the install with the fender on the machine? Looks like everything would be easily accessible this way.
I’ve performed it both ways…..initial installation with front tires removed and replacement led with fender off.
I thought the fender removal was easier for me while working on the ground. The challenge is tucking the wire loom away from tire so as not rub on it.
Don’t forget the dielectric grease on the connections…..and using heat shrink on connectors.
