Trunk lock mechanism
AbNormy
Well-known member
Took our 2012 RT A&C to central Texas power sports to get the passenger armrests installeon bike with 1000 miles,this turned into thesecond time they didn't have the parts I'd orders and paid for,so they decide to do the garmin install with Bluetooth wire but they said it required additional five hours after the fact, that I'd have to come back in. Ok but the belt was loose should have been paid attention to at 600 mi service apparentlywasnt,then I get it home and the trunk won't open. Anybody know why that happens? Is there a fuse blown?and does anyone know a contact with BRP quality?:banghead::yikes::yikes:
Norm Hartwell BMW MOA 351361
5126268096
When we picked up our 2011 RT it had a bad trunk switch and for the first 4 months or so I had to turn the key to the left to release the latch. My dealer was in contact with BRP on this issue and eventually the part came in and it was fixed in a short amount of time.
I hope this helps.
There are a number of possible reasons for the trunk malfunction. If the trunk does not work electrically (if so equipped) but works with the ignition switch, it may need adjustment and lubrication of the latch, or the microswitch may have a bent lever or have the connector installed wrong...or the trunk could be too full or the weather strip loose from the body. If it won't work with the ignition switch, it could be adjustment, lubrication, a cable that has come loose, or just a trunk that's too full. Try pushing on the trunklid while opening it. That usually takes two people. It it opens, and the trunk is not too full, have the latch lubricated and adjusted.
