The Doctor
I recall reading about it on the forum...... I cannot find it now.
Is there any issue with leaving the underside plastic panel off when I reassemble the right side of the trike? Any advantage? This is the one behind the radiator... Not the cupped deflector. It seems to be there to keep road crud from getting kicked up onto the engine.
If I do leave it off I assume I should keep the bolts in the holes to minimize stuff getting into the lower frame tube?
