Valvoline™ 4-Stroke Motorcycle Full Synthetic 10W-40 Motor Oil
So I thought I watched a BRP video on oil which shows a team of scientists working with the oil industry to create XPS. BRP spent a couple million on this process just for a specific engine brand. Valvoline spends a couple million on marketing for every major unit engine. And I just consulted with this thread of a dozen motorcycle riders who are probably not in the oil profession but read other professionals literature about the best oil and then write about it or debate about it. It drives me crazy that a good percent thinks xps is too much money and another group says it doesn't have the viscosity that is needed, or I sent mine in and it broke down faster than the other. I'm a big big believer in XPS because I believe in the Spyder which means I Believe in BRP. Btw I'm sure everyone on this thread knows more about oil than me that's great, keep up on that so I have more to read.
Who left the troll cage open again? lol lol lol lol
See, I can put a bunch of lol's at the end of my post too.
I tried the Valvoline 10-40 full synthetic and didn't like it. Made my spyder shift harder. Took it out and put Lucas in it. Shifting like it should now. Mine seems to not like it. Oh well at least I tried it. Was hoping to like it with the price of it. Mine is a manual shift also.
David
David
If that's working out well for you, that's great! I had used the Amsoil for a couple of changes and while I did notice a difference, for me it wasn't enough to justify the much higher price.
Switched to the Castrol for my last change and so far it's working fine for me. Reasonably priced too.
I updated my ( post # 11) on this thread ,that it EXCEEDS API Services SJ/SG/SF, JASO MA2.
I use this oil, I have not had any problems with this oil.
I have a 2014RTS-SE6.
Deanna
Good oil
Highly rated, readily available, good price. Get your filters from Baja Ron.
Valvoline Oil
I don’t want to start an Oil thread. I got a question. I have read a large number of all the oil threads with a lot of tests that were done. I have got it down to two oils that I am considering to start using. Those are Mobil 1 Racing oil T4 10W/40 and Valvoline Motorcycle oil 4T Stroke "Full synthetic" 10w-40. I have read the spec’s on both oils. They seem to be about the same. I can purchase the Valvoline for about $5.00 a quart and everywhere I have checked the Mobil 1 is $9.97 a quart. Is the Mobil that mush better?
oil choices
I use and like that Valvoline ....... here's something that might not be known about the Valvoline - Out of about 20 of the leading Mtc oils. This Valvoline had the second lowest Molybdenum added to the product, only Amsoil is lower ........... Moly is BAD for WET clutches .... and the Spyder has a Wet clutch .........Mike :thumbup:
Use the Valvoline and Mobil 1, run each oil 5,000 miles, have them analyzed and make your selection based upon the analysis results. That's the only way YOU can tell which is performing better in your Spyder. Buy oil analysis kits from your local Napa auto parts store or from Napa online.
Sorry I need help but this is an oil? Also, I am new to Spyder
I just checked the oil in my Spyder RT before starting it, & it did not show anything, also I don't see any leaks! Help?
Never check the oil cold. They say run it 9 miles let it run for a few minutes then check it. I just check mind now cold and it is on the minimum. If I run it several miles and check it it wil be okay.
I use and like that Valvoline ....... here's something that might not be known about the Valvoline ..... Out of about 20 of the leading Mtc oils, This Valvoline had the second lowest Molybdenum added to the product, only Amsoil is lower ........... Moly is BAD for WET clutches .... and the Spyder has a Wet clutch .........Mike :thumbup:
I also read that somewhere. That is why I am thinking about using Valvoline.
thanks i guess i will but oil in to med- run ride and chack that sounds ok right
Which Spyder do you have? The 998 engine burns oil, the 1330 doesn't. If you have the 998 and you don't see any oil on the dip stick, you better add a half quart before you go driving around.
Since it's a 2015 RT run it 9600 miles, the factory spec for oil change interval.
I don't think I will go quite that far but I will go around 7000 miles .
Jerry
Jerry, I use the Valvoline and like it ..... In Vermont I usually do about 11,000 miles per year, so I do an oil change around 5,500 mi..... However, at this change I don't do the filter just the oil ...... clean oil doesn't clog the filter the way dirty oil does... so I think the filter will last longer .......jmho .... Mike :thumbup:
The Valvoline oil is fully JASO MA2 compatible, go with it.
Where are you finding the Valvoline 4T 10W40 Full Synthetic for $5 a quart? I usually pay near twice that from either Wally World or Pep Boys.
