VCM vs. Electronic Box
derif
I have a 2011 Spyder RT A & C. Been towed now 5 times to different dealerships with various problems. The last one had the bike for 2 weeks before they even looked at it. Ran diagnostics on it and said the problem might be with the VCM. Operative word here is might. Cost me $300 (3 hours Labor) just to be told this. Nothing else was done to the bike. The tech reset the angle sensor.
Went on line to check out the cost of a VCM. $649.99 for part number 278001999. Not sure this is the correct part number for a 2011. Called GearHead.com and they told me the correct part for my bike was an "electric box" for $529.99 (part number 420666567).
Is an electric box and a VCM the same thing?
Thanks in advance.
Sorry..!!
The ECM ( engine control module) and the VCM (vehicle control module) are seperate units what I have found is...
VSS hydraulic unit 219800097...$1,133.99
ECM 420666563 US, 420666547 CA, $529.99
don't know what issues you are having. These are items that don't fail often. Perhaps a second opinion...:thumbup:
VCM is what we affectionately call the Nanny. Control the ABS Brakes, Vehicle Stability and Traction Control. The picture below is of a 2013 model and easier to get at then your 2011 but basically the same unit. There have not been many failures, but a couple were because water got in the electrical connector a caused corrosion. Did the tech inspect the connector?
attachment.php
Have you tried this
Do yourself a big favor and pull up the codes yourself and let us Spyderlovers know what they are and MAYBE someone here can save you a lot of MONEY..................JMHO.......Mike :thumbup:
module masters
COO6C code. According to tech.
wonder if ModuleMasters will be able to do anything with these? I found out the fixed BMW Abs modules after I had mine eliminated cause it was too expensive to replace. if it was definitively diagnosed might be worth inquiring with them. but for a dealer to troubleshoot with 'known good units' at your expense strikes me as incompetent.
