Volt meter installation on the F3T
Buckskin
Adding some farkels to the F3T this week and thought I would show the volt meter I installed in the dash. http://www.ebay.com/itm/351884215509?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
If you have any flat area on your particular bike, all you need is some space below it and the installation uses a 1 1/8" hole saw. Tape and then mark your center of hole and drill a pilot hole and then use the hole saw.
I ran my switched power from the "customer power lead" on the left side of the bike.
Buckskin
Yep I added one as well with 2 USB ports and a cap when not in use:2thumbs:
Buckskin
I like farkles that are actually useful!
Thx been looking for a clean small one like that for other projects I am working on too:thumbup:
I am looking to add the same type of adapter.
How do you remove the speaker grill cover?
Just yank it and it will come right out. If I add one of these it will be directly to the battery with a relay for when you turn on the key. Sometimes hooking to accessory terminals will show variations.
