VSS Warning Light
NaDSoB
2015 RT LTD , dealer replaced the rear suspension compressor last week. When riding home from the dealer, I noticed the VSS Warning Light was illuminated (it’s way too dim to qualify as a Warning Light and often hid under the Tach Needle at 2500 RPM).
Is it possible that the replacement of the compressor and the Warning Light are related?
Thanks!
I will say that my VSS and limp mode came on when my battery was borderline going bad. Wonder if they were trying the compressor without the engine going and drained the battery below what it should be.
Thanks!
There's a lot to take apart and put back together correctly for that job. As a quick check, lift your seat and check that they remembered to plug the pillion rider switch - aka passenger switch - back in. If they took off the rear wheel and went in from below, check that the rear speed sensor is reinstalled. Otherwise, start it back up so that the warning light is illuminated again and call up the codes. Don't use Google for the code explanation, post and search for it on here.
Or, take it back.
