BajaRon
Well-known member
Its really hard to adjust to this type of riding coming from a Goldwing, trying to maintain 4k rpm or above in traffic is difficult. Sounds like the engine is suffering, screaming for a gear change. Instinct is telling me to change up but fighting the urge is difficult. Sounds like the engine is going to bust out the spyder.
harry
It is hard to adjust from a low RPM, high torque engine to a high RPM, low torque bottom end engine like our Rotax. Coming off the Suzuki M109R torque monster I had to adjust. We have trained our ear and our seat of the pants for a different engine and format.
If you came off a crotch rocket to a Harley you'd have the same problem in reverse. Everything would be telling you something was wrong.
But I'm here to say that you CAN teach an old dog new tricks, as long as the dog is willing to learn.
When you need to change between 4.5k and 5k and you have to run above 3.5k thats a very small band width to drive at a constant speed. Wish they could make that better.
harry
That is just the point. You DO NOT need to shift at 4,500~5,000 RPM. The Spyder will be just fine if you go to 6K or even more. But to do this the rider must overcome their urge to keep RPM low and their fear of seeing that Tach needle going where none have gone before.
Is this damage mainly on the clutch, or have there been some engine / bearing damage as well? And if that is the case, could it be related to the oil pressure? I recall seeing a thread about oil pressure dropping at low RPM's...
Damage is mainly to the clutch. But the details are the clutch begins to desintegrate depositing parts and pieces into the oil. We aren't talking dump truck loads but still, a lot more stuff in the oil than you want. Oil filters can clog, lubricated parts can suffer. It's just something that you can completely avoid if you simply ride the Syder as designed.
Oil pressure will always drop at lower RPM but it should never drop to where it is an issue unless there are other, non-RPM causes.
Either there's something wrong with my SM, or it points to how much the SE clutches strain at low RPMs. I can't seem to maintain any speed at low RPMs. The engine just strains too much and I have to twist the throttle farther. I'd have to try it and see, but things seem to run really well above 3600 or so. There's plenty of power to coast or even accelerate from this RPM.
Sent from my ADR6400L using Tapatalk 2
The difference is your SM clutch is fully engaged, no slippage. If you constantly slipped your clutch it would act like a torque converter and you would be able to run lower RPM's with less difficulty. Of course you would smoke your clutch in the process because of the friction and wear created by slippage.
In other words, you would never run around in a manual transmission vehicle slipping the clutch all day long. But this is exactly what you are doing in an SE Spyder when operating at RPM's lower than what is necessary to fully engage the clutch. With, I might add, the same negative results.
Simply bump up the RPM and all of this goes away.
