Well that didn't go as planned
Sptech09
On my 2025 spyder rt limited I wired in an innovv power hub 3 along with front and rear dashcams. I added a Carling v1d2 on/off switch with four poles (pole 2 connected to battery, 3 connected to acc wire of power hub 3, and 8 to battery ground) every thing with this is working fine.
Somewhere along the way, I screwed up the switches for heated grips and heated seat. Moving the switch for the heated grips does nothing at all in any position grips will not turn on. If i turn on the heated seat the grips go all in on high but seat heat doesn't work. I can control the heated grips from the display as long as the seat heater switch is off.
To fit the Carling switch in, I disconnected all three of the switches and like a dummy I didn't take a picture before disconnecting. The switches are labeled "1"., "pos1" and "pos3." When I connected them back, I placed "1" for the windscreen switch, "pos1" for the heated grips and "pos3"
for the heated seat.
Does anyone have an idea of what and where I screwed up and how do I fix it? Ready to send it to the dealership to let them fix it.
Thanks In Advance for your suggestions.
I would say you have to start from scratch and trace back to all of your units and run them to power and make sure you have the polarity right! You may need to check the resistance on the grips and seat if they have a high and low setting and hook them up accordingly!
