What could cause this Squeal on starting out in first gear?
amkrat
I've read (I think) all the posts about chirping and squealing noises, but I haven't found anything that addresses my problem. When accelerating away from a stop, a squealing noise comes from somewhere up front. If I didn't know any better, I'd say it sounds just like a loose fan belt. Depending on how hard I accelerate, the noise will last for several seconds or more. if I really baby the throttle starting out, I may not get any squealing noise at all. Engine sounds are all normal at idle and while cruising. There is a lot of discussion about drive belt noises, but my dealer just replaced my rear tire and adjusted and aligned the belt so I'm not yet ready to blame a belt that has less than 10,000 miles on it. Is there anything else that could be the culprit?
Yea, chirping. My dealer just told me that it is the alternator shaft on my 2 month old RT L. Back ordered until September.
When you get it changed, please provide an update. I have the same noise and discussed it with my tech. He told me 2 other riders I happen to know complained about the same noise. On one of the rides, BRP had him change the alternator, and other parts connected to the alternator, but the noise remained. BRP determined it is not an issue that will cause a failure, so we keep on riding.
I've got like a harmonic humming going on that kind of comes and goes, I have to check out! I would like to ride another 1330 machine to see if it's a normal sound I am hearing or something I should get checked out!
It could be the torque shaft that drives the alternator. It is designed to slip under a heavy sudden load and will sometimes chirp/squeal when you accelerate.
I wonder if this torque shaft runs in engine oil. After reading Baja Ron's post about using Amsoil, maybe a little heavier oil would be the answer? I think BRP oil is 05W40. The Amsoil he used is 10W40. Not much difference there, but that might be all it takes. I've got an oil change coming up soon. I might try it, if I can find Amsoil locally.
Amsoil now makes a 5W-40 MCF. But I still think 10W-40 is a better fit for the Spyder. We'd all like to hear you results, should you give this a try.
Yes it is lubed in engine oil. Oil choice could make a difference.
I just did my first oil change and used Amsoil 10W-40 with a Hiflo filter. I can say without a doubt that it shifts quieter and much smoother than whatever the dealer put in when assembling my bike. I will be sticking with Amsoil from now on. We all do what we think is best for our bikes and I believe Amsoil is the best for me. I wish all the best.
Just went against my 10w40 preference yesterday by doing a oil change using Amsoil 5w40 metric motorcycle oil. I'll send it in for an analysis, but it'll be a year :)mmfqt-ea.jpg
You can order it online and it will be dropped at your door in a couple days!
My 2023 RTL has previously been chirping and I had an oil change at 2700 miles done with Amsoil by the best guys in the world at Baja Rons and it did not stop the chirping.Im in Deadwood at the rally and I decided even though Im not due for an oil change to let Amsoil Adam here change it.I can happily report that the Chirping is completely gone .Why it did not stop after the first oil change and did on the second i have no idea but as far as Im concerned the proof is in the pudding with Amsoil Oil.
