I switched from 2016 F3L to 2020 RTL this year - loving it.
We also have a 2014 RTS which I don’t like riding at all.
Thanks! Is the ride similar on both? I’ve read you set in the F3 and on the RT. I’m 6’5”, so looking for leg room.
Hey everyone,
Besides the limited having 2 more speakers, a removable top case, heated grips & floorboards, are the bikes identical? Also, anybody switched from an RT to the F3?
Thanks,
Pikester
Thanks for all the replies everyone! I need to find a dealership with both models in stock and go and sit on them. It sounds like they both are great, I just need to figure out which one fits me best. Ride safe, Pikester!
Hey everyone,
Thanks,
Pikester
Haze, can the top case be added to the 2020 & newer F3-T?What's the difference between F3 Ltd & F3-T?
The machines are the same in engines, frames, and wheel size. I can't comment on the shocks.
The T does not have the rear case or arm rests and rear speakers that are part of the Ltd.
The F3 series has the UFit system that allows 5 settings for footpeg/floorboard fit.
The seat can be custom tailored by (Seth Lamm) to move the driver back at least an inch from the OEM setup.
I ride an F3T with Ultimate floor boards, a Seth Lamm seat, and a BajaRon Ultimate Sway bar.
Can the top case be added to the 2020 & newer F3-T?
Sorry I can't answer that question. My experience is with 2017 & 2016 F3Ts.
I added LaMonster IPS Rear racks and HF Apache 4800 cases to both bikes. Wish I had a picture of this setup.
Works very well for me.
BTW, the OEM rear sprocket on the F3T is larger than the OEM sprocket on the RT & F3L.
I believe that you can add the top case to them using the U-Fit system. I have a 2016 F3 Limited Special Series. I added a Givi box to mine, mounted to a luggage rack. Keep in mind that the 2016 f3L did not come with the top box as an option, but it could be added later. But using the givi box was a lot cheaper option, and it was larger (54L vs 47L).Haze, can the top case be added to the 2020 & newer F3-T?
Thanks,
Pikester
I haven't looked into it, but is the top case easily removable and replaced with the cover like on the 2020+ RT?blacklightning,
I have a 2023 F3 LTD Special Series, it came with a case( which I can remove if needed) and a top rack.
Deanna
