Where can I find a SQUARE Trailer pigtail adapter?
I have a 2014 and will install a hitch, will my bike plug be the 4 plug or a 5 plug as my turn signals are yellow and my trailer is a 5 as i have seperate turn as well in yellow also. How will all this work???
The BRP harness/module is 4-wire, so it will not work directly with a 5-wire trailer. Simplest answer is to wire a 5-wire pigtail directly into the Spyder harness (or the wires that feed the trailer module). You could also change the trailer signals to red lenses if available, and splice in a 4-wire connector. Beyond that it would take trailer wiring modifications to convert it to 4-wire, disabling the separate signals.
Are you buying the BRP hitch kit, or going with after market? Are you doing it yourself, or having the dealer do it? If you can stand to wait for a couple of days or so I will post my hitch project. I installed wiring to handle my 5 wire trailer which, like yours, has amber turn signals.
It's a BRP and I will install it myself, I want all your good info and will wait :bowdown:
I don't understand, the spyder has separate running, stop, turn, is that not a five wire setup. My trailer has all the same lights as the spyder and my 09 Goldwing and it works when I tow it with that bike.I think I am missing something :banghead:
Yes, and no. The BRP kit includes a 5 wire to 4 wire isolator/adapter. They're readily available wherever trailer supplies are sold. It plugs into a Y harness that has available a power lead, plus the turn signal leads, brake lead, and tail/marker lead. Four wire trailer lighting is somewhat the de facto standard which, I think, is why BRP went that direction. Five wire trailer lighting is used a lot on motorcycle pulled trailers. Maybe that's because m/c riders are more enlightened! :ohyea: The Goldwing, if done properly, uses a trailer isolator with a 5 wire output. I used one of those plugged into the BRP Y harness to provide 5 wire power to my trailer. Plus, I tapped into the Y harness to connect my high mount brake light and turn signals.
As WasWinger said, the BRP harness contains a converter module, changing the 5-wire output to 4-wire to match the BRP trailer. The original 2010 modules and trailers were actually 5-wire, but they were not very reliable. They were changed in 2011. To use a 5-wire trailer you will have to tap into the Spyder lighting directly, use the Goldwing isolator module, or modify your trailer to make it 4-wire.
Square4-pin plug for trailer
The square plug that is needed from the Spyder to trailer is also available at your local NAPA AUTO PARTS.:clap:
If they do not have in stock, they can order.
I paid ± $5.00 for mine and it worked 100%:2thumbs:
I use the mail part of the plug as a "cap" for the trailer when the trailer is not in use. :ohyea:(Attached elsewhere to the trailer)
The part number from NAPA is 755-1570
