Where do I go to find how to Add flags and Spyder updates to daily posts?
ricford
I see many posters with information on their upgraded bikes and flags of US and Canada posted. I have searched and not found the answer. Point me to the right info spot on the site. And, I receive a message that I have a wrong email but I've posted the change many times and still get the error message. Help me.
Are you talking about adding things to your sig line so they appear in every post?? If so, check out this thread:
https://www.spyderlovers.com/forums...l-Add-your-Spyder-Year-model-to-your-Sig-Line!
I think it's post #4 that has the step-by-step process in it... ;)
As for the 'I receive a message that I have a wrong email', is that the 'Invalid Email' message you're getting? Can you quote it, or at least it's heading? :dontknow:
To fix that 'Invalid email' thing you need to go into Settings up in the Top Right Corner of the page; then run down the list in the Left Hand Column until you get to 'Edit Profile' & click on that; then click on the very top button to the Right, the one that says 'Edit email and password' - in there, you need to make sure you have a valid email address entered. If you then get a message on that valid email address asking you to respond, you need to follow the directions in that explicitly & respond to confirm that your email actually IS valid. :thumbup:
If you don't follow those directions properly, you'll keep getting the message until the system eventually dumps you and locks you out of the Forum, so if you think you've followed the directions explicitly twice or maybe three times and yet you're still getting the invalid email messages, then I'd suggest you use the Contact Us link to send a message to Admin, explaining your problem and including your current working/valid email address. ;)
Thread is from last year, but if you ain't found the flags, smilies, and other little pictures, I will tell you where they are.
Look at the top of the posting box and click on the little smilie face.
Another one just like it on the box to set up your signature. 🧚‍♀️🧙‍♀️🦣🐎🐓🐈‍⬛🍿🎯🚙🏁
