Which GPS fits Garmin 660 GPS mount?
Disisme
Hi folks, the 2022 Sea to Sky I’m picking up has the Garmin 660 GPS mount but doesn’t come with the 660 GPS. Which GPS is recommended for this mount, other than the very expensive 660? I normally just use Google Maps on my phone, playing directions over the sound system. Thanks,
Lynn.
Sorry I should have included a pic:
I assume it's a Garmin Zumo 660. The S2S did not come with a Garmin Zumo; it was added. The cradle / mount will fit a Garmin Zumo 660 and 665. You can find used head units sometime on Face Book marketplace or eBay a lot cheaper then new.
You maybe able to remove the mount and add a phone mount than use BRP connect for maps. Here is the manual if you don't have one. https://www.operatorsguides.brp.com/M/1976
Used Zumo 660s on eBay are only around $200. There are 5 of them for less than $230 right now, including one 665. If you don't need/want XM Radio, get the 660. Loading current maps on a 665 takes a bit of a work around. The 660 with an add on memory chips loads them just fine.
jdg
Given you have the RAM mount, likely not worth chasing an older series Garmin IMO. They were good, but the processor etc is way out of date. I would changes over to an XT2 or XT3 Garmin, or what I did was add a Carpuride device so I had Android AAuto and Carplay. Carpuride mades a wide range of devices, varying prices and sizes. I did the 702 Pro. Carpuride does use your phone for for guidance etc, unless you get the 702 Plus that allows you to install apps on board.
I just put the Garmin Zumo 665 (same as the 660 but also has XM built into it) on the Spyder. I current run it on the Harley and wanted the capability to move it from it to the Spyder. I got the harness with the detachable mount from a friend, but I was looking on eBay and there are a few there. I have the Carpuride W702 and use it from local riding, but use the Garmin when we have groups rides. As an example; I can create a route with bio stops and canyons in Basecamp and load it into my Garmin to lead. I can also share it with others who have a Garmin to follow. You can’t do that with google maps or Waze. I run into problems with the Carpuride when using the Garmin, phone, Sena 50S since they all require Bluetooth (BT) connections. Granted the Carpuride W702 & Pro can handle 2 BT but I found problems when trying to use my Sena50 and my wife's, the Garmin, and my phone. Found it easier to use the audio out from the harness into the Spyder audio in. My Garmin also has XM radio built into it, so I get the best of both worlds. I got the dual ball mount handlebar cover from Slingmods to mount the Garmin. Here is what my setup looks like. Granted, because of the XM, you’ll see that I have to add the antenna for it.
The only downside to the Garmin Zumo 660/665 is that Garmin no longer supports the maps for them, but you can get Garmin Updated maps at Openstreetmap.com. The other downside is that the screen is horrible in bright sun. Today TG I could hear the turn by turn because the sun washes out the screen where you can barely see it, even with a shade like I have. Eventually I will go with a XT2 when the time comes, but for now my 665 is fine.
20260820_173417.jpg 20260820_173440.jpg 20260820_173601.jpg 20260816_065037.jpg
View attachment 256842 View attachment 256843 View attachment 256844 View attachment 256841
Mostly true - there is no support for the 665, but the 660 will still download the current maps. To get the maps on the 665, you need to build the map in Map Install then run it through an unlocking program, then copy it onto the 665 (with aux memory installed). Then you have the current map on the 665. A bit of a PITA but it works. Just installed 2027.20 on both my 660s and my 665s.
jdg
jdg
Your right! Forgot the 660 is still supported where my 665 is not. I found that method of loading the map cumbersome and painful at times.
I found a great site that you can download the most recent Garmin maps (Open-source maps) for free and install them in 5 minutes by basically renaming the image (img) file and then copying it into the SD card under Garmin. I accidently stated the wrong site in my last post and is not
OpenStreetmap.com; it is https://www.openmapchest.org and it’s a free download. There current map I loaded a week ago is 2026.8.29 US West and it worked today flawlessly. I haven't had any issues with their maps. The screen does washout pretty easily and I've tried using the dark and light background which each has its inherent problems in daylight.
When I get a few bucks, I'll upgrade to the XT2; but for now, need a windshield and exhaust first on the Spyder (Priorities :)) . If you’re not using Basecamp, it's free and great creating routes and rides. I also use it when planning a trip with all my stops (including gas and hotels) for each day/night. Works well and uploads right into our units. I do turn recalculate off on the Garmin because it will bypass part of your route. Thanks for getting back to with that info. Mike
On using GPX files with the Carpuride, while it is correct that Waze and Maps can be challenging with GPX files, there are other tools. I use Sygic and MyRoute App, both of which can read GPX files and are Android Auto compatible. They both also use stored maps, so do not require a data connection to use them (so there is no issue if cell service drops). Just an alternative to an older Garmin while bringing full AA and/or Carplay functionality.
Thank you for that and I'll load them onto my Samsung 25 Ultra & try it on my Carpuride W702. Would make things a lot easier since the Carpuride screen is great in bright sunlight. I use the Garmin mainly on my Harley since it is Pre-Bluetooth capable and I can connect the Garmin into the onboard Radio/CB (Audio in jack) for Turn-by-Turn directions with XM Radio through my wired headset. Was thinking about getting Hogtunes Bluetooth Wireless Music Connector for it (which takes the place of the worthless temperature gauge), but I'm riding the Spyder more these days and just lovin it. Great info and really appreciate it!
jdg
Hi! I saw your post here and you might be able to help me, or refer me to where or who I can ask. I still have the Garmin Zumo 660 from the 2013 Spyder RT (pictured - since sold) and I now have a 2014 Spyder RT with a Zumo mount. I have been using the Garmin from the 2013 Spyder on my 2014 Spyder, but that GPS is very old, and does not show maps anymore, (streets, etc) so I assume it's because I have never updated it (I've been on Spyders since 2020, when after my last MC accident, I had to give up 2 wheels). I am not tech savvy at all, and I found the Zumo difficult to enter info into, since pushing any of the letters or numbers on the keyboard was agonizingly slow, so I never used it for that. I mostly just used it to tell me my actual speed, and show me map pictures of where I was, since my Spyder's speedometer is wrong at higher speeds.
Anyway, the point of this post is to ask if you know of a Garmin that will work on my Spyder (I am assuming a Garmin so that I can use the same mount) and which can be used in my car. My husband and I are ditching our cell phones (switching to a burner during rides) but we do use Google maps for navigation when driving sometimes. AND, it has been so long since I asked a question on the forum that I don't really remember how to do it. I don't remember how to just put this OUT there, so anyone and everyone can answer. Can you help me with that too?????? Thanks so much my friend. Spyderlovers forum has helped me so much from the very start of owning a Spyder. I like this forum very much! Thanks again.
...we do use Google maps for navigation when driving sometimes. AND, it has been so long since I asked a question on the forum that I don't really remember how to do it. I don't remember how to just put this OUT there, so anyone and everyone can answer. Can you help me with that too?????? Thanks so much my friend. Spyderlovers forum has helped me so much from the very start of owning a Spyder. I like this forum very much! Thanks again.
So you can create a route using Google Maps, then paste the Web URL into a website that will convert the route information to a GPX file. GPX stands for GPS Exchange Format. Google listed the following website as possibility:
Maps to GPX: https://mapstogpx.com/
Then plug your Garmin Zumo into your computer using the USB port on the back of the Zumo and you can then copy the GPX file to the correct location on the Zumo.
[snip]
The 660 or the 665 will work with that original 660 mount (as will the BMW Navigator IV and one of the H-D units which is also a 660 with an H-D badge). There is a car mount and 12-v power adaptor for the 660/665. It was in the original box and can be found cheap on eBay. If you are asking if another Garmin model uses the same 660 mount, then the answer is no. That mount does not work with anything newer.
The 660 is older and not nearly as fast to calculate routes, accept input, and display changes, but it still works just fine. If it has a map loaded, it should display, providing there is nothing wrong with the unit itself. You will probably get a warning that the maps are more than a year out of date, but it will still display. The other thing it could be doing is having a map loaded for another area of the country. If I only load the SW USA map and head into Texas/Oklahoma/Louisiana it only displays a very basic map of the major highways. All the detail is gone. I seldom load complex routes into my Garmin. I use it mostly for point to point navigation. I do the big picture stuff with paper maps and an old copy of Microsoft Map Point, which is still good for the majority of any route planning I need to do outside of rallies. Basecamp, while a PITA to use well is where I plot rally stuff (mostly) when not using one of Greg Rice's tools.
I recently loaded map 2027.20 onto my 660s. It still shows up with the current map available in Garmin Express, so you shouldn't have any problems getting the latest map directly from Garmin. You do need to have an aux memory card installed in the 660 for the installation to work properly.
I hope that answers your questions. If not, message me directly and we can go into greater depth.
jdg
