Why does the BRP Oil Change Kit have 5.5 quarts of oil?
CRSpyder3
I haven't done the break-in service yet on my 2024 F3-S. In preparation, I purchased an oil change kit from my dealer. Included were all of the O-rings, the drain plug gaskets, the oil filter, 5.5 quarts XPS Full Synthetic 5w-40. A very convenient package.
My question is why do they have 5.5 qts? The 1/2 quart is even in a tiny 16oz. bottle. My owners manual and the shop manual calls for only a 5 quart change with a filter replacement. What gives with the extra bottle? It says for 1330 Rotax. Does another model/year require more than 5 quarts?
When draining from the 2 plugs, if OEM draining plugs, 1 is 41 or 45mm torx, 1 is 6mm hex. Then you fill with 5 qts; and use the check procedure in the book for checking the oil level. Then, if necessary, add any more oil needed from the small bottle. I'm surprised they just didn't add a full qt as extra, for being able to just use a small amount.
If one removes the crankcase plug, the left one requiring a T45 Torx bit; and the clutch cover, aka transmission plug, the right one requiring a 6mm Allen or hex bit, not a socket; and then lets all the oil drain into waste pan(s); reinstalls both plugs; pours five (5) quarts into the engine; starts it and lets it run until the cooling fans cycle on and off twice; turns off the engine; and then within two (2) minutes, checks the oil level, it will read right at the Min level on the dipstick. If one so desires, one can add the remaining oil from the half (0.5) qt bottle, the engine will have adequate oil to go 9,300 miles or one (1) year, whichever comes first. BRP, in its infinite wisdom, knows the company will sell Spyders to owners who think they are intrinsically smarter than the Rotax engineers who designed the 1330 ACE engine, and can therefore pour in another full quart instead of the 1/2 qt bottle and there will be no problem, when they will in fact be overfilling the engine, and some of these individuals will complain on some Spyder owners forum that their problem is BRP’s fault. Remember, MURPHY WAS AN OPTIMIST!
As a suggestion, why not take the opportunity to switch-out the OEM socket drain plugs with aftermarket hex-drive plugs? They are not expensive, readily available (Lamonster Garage, Baja Ron, Value Accessories, etc.) & might save you some grief in the future.
Well, that's a good question. My guess and only a guess.
Sorry, to crazy of an idea. I'm done with an answer.
Tip: Always put in the 5 quarts and then do the oil check process.
Works for me every time.
Have yourself a Spyder Time. (y)
Strange as it may sound, its not the same on all 1330s. We always start with adding 4 quarts and then warm and check from there. A great majority of them only need another half quart to put the level mid scale. VERY few need more than 5 quarts. Some get to mid scale with just 4. I think, although I cannot prove this, it has to do with how well the HCM drains when you remove the oil filter and let air into the system. They almost always need a bit over 5 quarts when changing the HCM filter and that is why the kit includes the 5.5 quarts. Most don't need it without an HCM filter change.
I got rid of those Torx things with hex magnetic Gold Plugs.
Be careful not to over torque them. The engine side plug is easy to shear off at the threads, up inside the engine. Have had several of them break off when removing them, indicating the last person that installed them over torqued them. Removal is a bear when this happens. We no longer will install them, as they are a defective design with the magnet too close to the O-ring groove. There is a reason the factory plug does NOT have a magnet installed in the end of it, and it's not cost savings.
