Rednaxs60
Started thinking about this project when I bought the bike in 2015. wasn't until just before C-19 that I started to research it, and start getting my mind wrapped around a project of this magnitude, never thought it would morph into what it has.
Started with a replace the ECU because if the ECU goes "south", only options are a used ECU, the bike is parted out, the bike becomes a lawn ornament or boat anchor, or install an aftermarket ECU.
Looked at the installation of an aftermarket ECU, starting with the budget, most popular ones, MegaSquirt and Speeduino. Most others were not in the budget range. Settled on Speeduino because it is still in development, many new features being added, lots of variety depending on your requirement(s).
The Speeduino uses an interface board between the OEM system and the microprocessor, an Arduino Mega 2560. The only limitation with the Arduino microprocessor is the processing power and the program size limitation. For most of us the Arduino Mega will probably be more than needed.
The first Seepduino ECU was a Speeduino interface board v0.4.4 by Josh Stewart, with an Arduino Mega. Very capable, but did not have everything I wanted. Swapped out for a Spark Gap X4 by openlogicefi. Smaller footprint with integrated baro sensor, and other good attributes. The Ocelot by wmtonix is also another good alternative.
The Speeduino community is working on upgrading the Speeduino ECU microprocessor for more functionality.
The engine tuning software is Tuner Studio, and the data log analysis software is MegaLogViewer. Both excellent apps, but to get the most benefit out of these, you'll need to purchase a licence.
Have finally settled on a MaxxECU Sport for the final install. Changing out ECUs, even if they are budget ECUs, does get expensive. The MaxxECU Sport is a significant upgrade with the requisite cost. A fellow in Sweden that I correspond with is using the MaxxECU Mini, the baby of the family, which is a very capable ECU for any installation.
If a project like this is considered, I'd recommend a very realistic look at your requirements, because as I mention, changing ECUs can get expensive. The features/functions between the Speeduino and MaxxECU are very similar with some significant differences.
Next post will be on the requirements, I just wanted to start this thread and get started as @pegasus mentioned. It's a project that's not for the faint of heart.
Cheers
Cheers
