1985 Honda GL1200 Limited Edition Computerized Fuel Injection System Upgrade
Have mentioned specific tuning and new CFI configuration regarding the IAC system upgrade, and using LTFT for VE table calibration.
A small tuning aspect is to compensate for the different fuel injector latencies. I have checked Tuner Studio and could not find a fuel injector offset calibration; however, the MaxxECU has this function. The premise is that injector latency can have a cylinder operate in a lean or fuel rich condition. This is true and I have experienced it. This is the main reason that fuel injector data is very important.
I have OEM Bosch 360 cc/min fuel injectors that have the OEM latency information for each individual fuel injector provided. The ECU settings can be for a "gain" setting used for higher power up to full power, or for an "offset" setting for low powers and engine idle. I am more interested in the "offset" calibration.
The base injector latency is an average of the four injectors or can be a chosen value that would be appropriate. The four injector latencies are: injector 1 - 0.41ms; injector 2 - 0.355ms; injector 3 - 0.368ms; injector 4 - 0.41ms. You can choose either the upper value of 0.41ms, or the lower average value of 0.36ms for the base value.
Using a base injector latency setting of 0.41ms, in the injector calibration section under Offsets, set the injector offsets to: injector 1 - 0.0; injector 2 - (-0.6); injector 3 - (-0.42); injector 4 - 0.0. When the ECU calculates the injector pulse width using a base latency of 0.41ms, the injectors that have a lesser injector latency are being held open for longer than necessary and the affected cylinder(s) will operate in a fuel rich environment. If the injector latency is greater than the base injector latency, the affected cylinder(s) will operate in a lean fuel environment.
You can use the lower injector setting of 0.36ms. This would make injectors 2/3 have a "zero" calibration and injectors 1/4 have a calibration of 0.05ms.
Having mentioned this, injector offsets will be used but after the VE tables are better calibrated.
Just another aspect of engine tuning with an aftermarket ECU.
It's in post #3. Sequential fuel and ignition. Best option for this old girl. A new aftermarket stand alone ECU makes this rather "easy" relatively specking. Keeping the OEM wasted spark and paired fuel injection keeps component cost down, but you're dealing with components that have no component data scubas latency, dwell times and a person will need to sped additional time experimenting with component settings to dial in the engine tune. Sometimes it's better and faster to use an "out with the old and in with the new' philosophy.
Time to update the new configuration:
MaxxECU Sport
Spark units have been replaced with a Bosch 211 four channel coil driver
Ford COP units
External Lowdoller Motorsport MAP sensor
External Lowdoller Motorsport Fuel Pressure sensor
Hall effect sensors for crank and cam shaft sensors - Cherry GS100701
OEM TPS
OEM Bosch 360 cc/min fuel injectors - sourced from Canadian Performance Injection (CPI) Alberta Canada
MAP vacuum block - integrates all 4 cylinder vacuum connections
Aftermarket FPR valve - maintains system pressure at approximately 40 PSI
Dual O2 sensors, one for each cylinder bank - provided by MaxxECU, integrate nicely with the MaxxECU
Recent Addition(s):
IAC Motor - Walker product 215-1061
The OEM CFI IAC system will be completely removed. Mentioned in a previous post that the IAC system reed valves would be "gutted" and reused; however, this will not be the case. Has to do with supplementary air supply hoses. It is recommended that these should be equal length to each cylinder. The original OEM CFI IAC hose routing goes to cylinder 2/4 first then to cylinders 1/3. This creates an imbalance where cylinders 2/4 get a better supplemental air supply than cylinders 1/3. Small issue but needs to be addressed.
The new configuration will be the new PWM IAC motor supplying supplemental combustion air to a vacuum/mixing block, supplemental air hoses to each cylinder, equal length. The recommended supplemental air hose ID is 5 mm. Have to admit that I'm using AI for a lot of the leg work and have to sift through the information to make an informed decision. Looked at some pictures I have of a stepper motor IAC installation and the 5 mm size should work.
The installation of the IAC and crank trigger wheel should be the final component change after which it's road trials, and enjoying the bike. Engine tuning will be ongoing, finding out nuances such as fuel injector offset/gain calibration will not impact on riding this old girl.
Cheers
Have the air chamber out and the original CFI IAC system removed, IAC valve, water hoses. Bought a new Bosch NTC CLT sensor and have it installed. These don't last forever, so a small upgrade it is. Rad and right side timing belt removed waiting of the 36-1 trigger wheel.
Bought a contactless, sometimes called a Hall effect, TPS. Since I have a bit of time waiting for parts, I have been looking into contactless TPS, versus contact TPS. Always thought that when a TPS was contactless, it somehow did not have a mechanical shaft linkage between the throttle plate(s) shaft and the TPS. A mechanical shaft linkage will always for the foreseeable future, have a mechanical shaft linkage.
The contactless aspect is internal to the TPS. The older style of TPS use a metal brush - "wiper" that scrapes across a track inside the TPS. This is why a TPS can become faulty at certain RPM ranges. The wiper and track become worn.
A contactless TPS uses Hall effect technology. The twist of the throttle, a magnet turns over a stationary electronic circuit board without touching the circuit board, ergo contactless. It is because no moving parts interface, a contactless TPS should not wear out.
This new technology TPS unit is smaller than the original OEM CFI TPS. This TPS is 20 mm in diameter, the original CFI TPS is 30 mm:
These TPS units come in varying activation degrees such as 90, 120, or 360 for example. Regardless of the activation degree, when not installed the shaft will rotate easily through a range of 360 degrees. You must also ensure that the TPS rotation is the same as the original. For my project, the TPS must rotate CW, will be confirming.
The unit I am going to install has the contact pins identified and these pins are made to have the contact wires soldered to these pins:
The TPS I am using has a "throw" of 90 degrees, even though the shaft will rotate through 360 degrees. You have to connect the new TPS to a 5V reference and turn the shaft CW until the voltage starts to move from a base of 0.5V. This is the idle setting for the TPS. Continue turning the shaft until the voltage maxes out at 5V.
Most electronic geeks know that if you cut one end off a USB cable, strip back the sheath, there are red (power) and black (ground) wires. Plug this modified cable into a charging brick, you have a 5V supply. I did not know this but tried it, and it works!
This unit will take a bit of finagling to get it installed. Have to make an adapter plate, and a connector for the "tang and fork driver system". Apparently this is what it is called, have to call it something:
Next step(s) is to make the adapter plate and "tang and fork driver system" connector called a "drive tang collar", and determine where the TPS min/max limits are (mark TPS). The exact position of the min/max limits is not as critical as with the OEM CFI system. The OEM CFI system needed the calibration to be quite exact whereas in the MaxxECU Sport you calibrate the TPS in the fully closed and open position. The MaxxECU then determines a voltage range from "0" to 100 percent based on these two voltages.
Cheers
Have competed the new TPS install and calibrated it. The "drive tang collar" is a piece of ABS sheet and works well. Have been testing to confirm "repeatability":
Have also been working on the new PWM IAC system install. The OEM CFI IAC system was state of art back in the day, but it was an unregulated supplemental air supply into the cylinders. This was not an issue for Honda, because the CFI system was designed and installed at the factory to work and work well it does. The issue is trying to incorporate this into a new aftermarket EFI system that has more specific requirements.
The OEM CFI system has a thermostatic bi-metallic IAC valve. The internal air inlet orifice is wide open when cold and reduces, never fully closed, to a smaller opening when the engine is at operating temp. This valve never fully closes because it provides supplemental air to the cylinders when decelerating and at idle, hence the unregulated air during engine operation. Supplemental air is "sucked"/pulled into the engine cylinder through a mechanical reed valve that is cylinder vacuum operated. The inlet pipes are just downstream of the throttle plate(s).
There are three issues with the OEM CFI IAC system. First, as mentioned, there's the unregulated supplemental air supply through the IAC valve. Second is the mechanical reed valve, which creates significant turbulence in the supplemental air stream and cannot be guaranteed to be repeatable. The engine vacuum can change over time and if there is reduced cylinder vacuum, there is an impact on the opening of the reed valves. The reed valve internal "reeds" can also weaken with time. Third is the "plumbing" hose installation...
I looked into the design aspect of an air supply system with respect to the internal hose diameters. There is a lot of information on-line regarding this. If you have the space and can accommodate all the recommended hose sizes, great, if not you have to compromise. I have settled on a 9 mm ID supply hose to a vacuum/mixing block, and from this block, 5 mm ID hoses to the cylinders. Should work well and is close to what Honda had installed.
Did some additional investigation into the hoses and "T" fittings of the original IAC system hoses. Honda had inserted a rubber 4 mm restrictor in the air inlet to each reed valve. This indicates that Honda decided that a 4 mm supplemental air supply was all that was required for engine operation. This is interesting in that if the reed valves fail or are faulty, a vacuum/mixing block with 4 mm hoses to the cylinders may be used as an alternative repair. Something to contemplate.
I had agonized over the new PWM valve system hose sizes and this last bit of information convinced me that the hose sizes I will use are going to work just fine.
These pictures are of the final PWM valve and hose installation:
CFI IAC T Piece 3.jpeg - IAC Plumbing 1.jpeg - IAC PWM Vlave Installed 2.jpeg
The first picture illustrates the original "T" piece with the rubber restrictor removed; the second picture shows the new hose and vacuum block install - hoses are equal length; and the third is the PWM valve installed where the original IAC valve was located - the outlet hose barb is 9 mm ID.
AI has entered this world and is a great tool if used as such. It is not a substitute for critical and common sense thinking, but it can be a good assistant. I queried several hose size iterations and the response back ranged from good, okay, to not recommended. After exhausting my options, I finally decided on the way ahead based on space considerations, what Honda had designed, and what made sense. If needs be, I may revert to Plan B.
Wiring is being completed and a handlebar switch is being installed to turn the ECU data logging on/off during road trials. I was going to use the original IAC valve power supply that is shared with the fuel pump, but one aspect that may be an issue, probably not, but... is that the fuel pump power supply is cycled when ignition key is turned to the ON position. The fuel pump is started for 2-3 seconds to prime the fuel system, and then stops. The fuel pump starts immediately when the engine starts. Depending on how particular you are, the start/stop/start of the PWM valve may not be the best option. So I will be wiring the PWM valve power to the accessory fuse block. This accessory fuse block is powered on when the ignition key is turned to the ON position through a relay and powered off when the ignition key is turned to the OFF position. This specific 2-wire PWM valve is not polarity sensitive.
Update: Mentioned the modernization of the OEM CFI IAC system. Installed a PWM IAC valve that flows too much supplemental air for the GL1200 engine. Installing a smaller one this week.
Have done some rewiring, installed shielded cable for the crank and cam hall sensors. Was using the OEM pressure balance (PB - MAP) sensor unshielded wiring, but this has started to be problematic. Should have used shielded cable from the get go, but the system was working well, or so I thought. The takeaway from this is that we backyard DIY mechanics know better than the engineers, Eh What!:cool:(y)
Have been doing road trials and using Claude AI to do the number crunching, and it is working out well. Use Claude AI to search on-line for specific issues and the responses have been quite good. An AI can search on-line and return information in less time than I can make a coffee; however, it behooves one to have a good grasp of what is being queried, and to ensure the information is based on what the requirement is. An AI will fall off the "wagon" so to speak, and you have to correct the assumptions up front.
Have enabled Acceleration Enrichment (AE), and overrun fuel cutoff (OFC). These two functions are joined at the "hip" in that AE settings impact on OFC performance. OFC is interesting in that when it kicks in, it feels like a mini "Jake" brake because fuel is completely shut off; however, the engine does not come to a grinding halt because the PWM IAC valve lets air into the cylinder(s).
Idle control during cold engine starting, relative depending on the time of year, and up to and at engine idle when warmed up is a challenge. The PWM IAC valve is a key element to this in that it assists in engine timing for fast idle and when decelerating to an idle. The idle control I am using utilizes ignition and air for idle control.
The fuelling strategy has been changed to a "blended" fuelling strategy in that the engine tune uses speed density (SD) fueling for start up, idle and low powers up to 2000 RPM. From 2000 to 3000 RPM, the fuelling strategy is transitioned from SD to alpha-n (AN) and from 3000 RPM to WOT, the fuelling is 100% AN. The difference between the two is that SD uses engine MAP for the engine load component, and AN uses TPS for engine load. This setup mirrors what Honda did because the OEM CFI pressure balance (PB - MAP) sensors maxed out at approximately 3000 RPM and after 3000 RPM the engine tune switched to an AN fuelling strategy. The challenge with this blended fuelling strategy is to determine which fuelling (VE) tables need to be adjusted after doing a road trial, the main VE (AN) tables, or the SD extra fuel table. Working well so far.
The aftermarket contactless TPS has been removed and the original OEM TPS put back in. The reason for this is that the new TPS does not have a spring loaded drive tang collar (connector to the throttle plate connector) and as such if this drive tang collar is not a tight fit to the throttle plate connector, the signal to the ECU will be forever changing, even if only a small amount. The OEM and most aftermarket TPS units drive tang connector are spring loaded and this collar is kept firmly against the throttle plate connector because of this, no wiggle room. I will revisit this at a later date to fix this issue.
I correspond with a fellow in Sweden who is doing an EFI project, stuffed a 1985 GL1200 fuel injected engine into a GL1100 frame. He uses a MaxxECU MINI, smallest of the MaxxECU family of aftermarket ECUs, but uses the same engine tuning software. We collaborate on the engine tuning and it is a good exchange of ideas, issues, and remedies.
Till next time.
What is the exact reason why shielded was used? Isn't MAP analog voltage based? This would suggest it is not prone to noise.
Why WOT so fast? What is your current rev limit? Do you use any knock sensor on the motor?
Shielded cable: Honda did not use shielded cable for the crank and cam sensors, did not use any shielded cable for any sensor, on the 1986/1986 GL1200 FI models because it used variable reluctance sensors, analogue. I have changed these sensors to Hall effect sensors that should use a shielded cable, or these sensors are susceptible to EMI.
The MaxxECU wiring harness uses shielded cable for the crank and cam/home sensors regardless of which type of sensor used. I have mentioned I have an external alternator installed in place of the 3-piece alternator, rotor, stator and external RR from the OEM, and it can be an issue with the OEM original wiring. The OEM wiring harness is crammed into a very restrictive space, and bundled together so anything happening on a wire can be transmitted to another.
The MAP sensor wiring is not using a shielded cable. I mention the MAP sensor in my previous post in regards to the blended fuel strategy.
I will probably never get to WOT because it is not my riding profile. I mention it above because the AN fuelling using TPS as the engine load is 100% from 3000 RPM and up to WOT, not necessarily meaning I will ride at WOT.
The interesting issue with the 1985/1986 GL1200 fuel injected models is that Honda encoded two SD VE maps and two AN VE maps into the hardware. I can only surmise that two SD and AN VE tables were because Honda designed the engine tune around each cylinder bank. There are subtle differences with fuel pressure, injectors for each cylinder bank that makes each cylinder bank unique.
For the 1985/1986 GL1200 bikes, the pressure balance (PB - MAP) sensors (Honda calls the PB sensors MAP sensor in the ECU program) max out at approximately 3000 RPM then the OEM CFI ECU switches to an AN fuelling strategy for 3000 to WOT engine operation, and switches back to SD fuelling on the way down at approximately 3000 RPM, seamless transition regardless of the switch/breakpoint.
The blended fuel strategy (partial repeat from above) was done because these GL1200 engines have a very narrow MAP window from approximately 60 to 95 kPa for all engine operation. This makes it difficult, not impossible, for the ECU to interpolate SD VE table values for fuelling calculations. I use an SD extra fuelling table for engine operation from start to idle, and up to 2000 RPM. The transition to AN fuelling is from 2000 to 3000 RPM. The reality is that a GL1200 rider does not stay in the 2500 RPM and below range too often. These engines rely on the power band for get up and go, not engine torque. Power band starts at approximately 2700 RPM or so.
The settings for blended fuel transition is:
2000 RPM and below: 100% SD
2250 RPM: 75% SD - 25% AN
2500 RPM: 50% SD - 50% AN
2750 RPM; 25% SD - 75% AN
3000 RPM and above: 100% AN
This is working out well. The challenge is when calibrating the VE tables, which VE table gets calibrated. This is being worked out and is progressing nicely. Using the MaxxECU SPORT MTune long term fuel trim (LTFT) tables to calibrate the VE tables based on the road trial results. LTFT indicates whether there is a need to increase/decrease fuel to the engine. It is an accepted short term fuelling trim (STFT)/LTFT tuning percentages to be less than +/- 5% for the STFT, and less than 10% for the LTFT. The closer the LTFT is to "0"% the closer the STFT percentage will be as well because the STFT is the "right" now indication of the O2 sensor reading, LTFT is the O2 sensor reading averaged over time.
I have read about an ECU "learning". This is directly attributed to LTFT. LTFT is an averaged O2 sensor reading over time and can fluctuate +/- depending on your driving/riding habits. This LTFT percentage is used in calculating the fuel injector pulse width, increasing/decreasing it as required. For example, if the injector pulse width is calculated to be say 2.3ms, and the LTFT at the time is 5%, the pulse width will be multiplied by 5% to give the engine the required fuel for operation, works the other way as well. STFT must be in the calculation somewhere but haven't found it yet.
EFI is all about fuelling the engine so that the air-fuel mixture is as close to a correct Lambda value as possible.
I have the Lambda target table set up a bit rich say 0.98 instead of 1.0 (small difference but relevant) and will calibrate it further when the VE tables are much better dialled in. After the Lambda table is calibrated it's on to the ignition timing table. There is no "dyno" available where I live so it's go for a road trial, check the log, make a correction, rinse and repeat. The Lambda target table values used are generic from research I have done. I have learned from various forum searches that Honda apparently and purposefully designed its engines, the GL1200 engine is no different, to operate in a lean fuelling condition to increase fuel economy without sacrificing the engine. This is supported by my being able to get 50 IMPG from my 1985 GL1200 FI model.
It's quite a learning process.
The AI came up with a very specific 3 phase tuning program for road trials.
Phase 1 - straight and level road - targeting 40 to 60 kPa: in 3rd gear and stay in third gear, start at 2000 RPM and work your way up to 3500 RPM in 500 RPM increments. This is to target the 35 to 60 kPa range, and to populate the primary cruising cells.
Phase 2 - Lugging the engine - targeting 65 to 85 kPa: moderate incline in a higher gear say 4th, start at around 2000 RPM and smoothly apply throttle to climb without downshifting. This forces the engine into a high-MAP low RPM cells that are hard to hit on flat ground.
Phase 3 - smooth wide open throttle sweeps - targeting 90 to 100 kPa: using 3rd gear (stay in 3rd) and on a level road, smoothly accelerate to say 5000 RPM. Repeat 2-3 times.
To capture this data, will need to first do the 3 phases once and look at the Fuel Adaptation tables to determine what info has been captured and how the information has been used to populate the fuel adaptation tables. May need to adjust the MAP axis kPa values for a certain phase. Think that three road trials per phase should be good, and will quickly dial in the VE tables.
I was aware of each of these but this is the first time it has been presented in a concise manner.
Have been delving into the MaxxECU data log capabilities and these are significant. MegaLogViewer is a powerful dat analysis program, but it is separate from the engine tune. The MaxxECU data log analysis feature is integral with the engine tune. You can configure the data anlysis such that you have separate tabs for parameters that are related. For example, one tab for O2 readings, one tab for fuel related parameters and so on. This way you don't have to sift through the plethora of logged data points. These data page tabs are kept in the main memory and are applicable to any MaxxECU data log.
One very "cool" feature of the data analysis feature because it is connected to the engine tune being evaluated is the ability to make changes to the engine tune from the data log.
Next thing I will be looking for is a man servant droid! :lol: :lol:
I am the the man servant droid in my household.
