2011 RS w/1500 miles wont start - troubleshooted and resolved.
markjperry
Went for a short drive, picked up a friend as a passenger for 15 minute ride. After the ride I shut off the bike it would not start. Turn the key, full instrument lights and no error. When I pressed the M+ Starter button -
Nothing. Everyone recommends battery terminals. I removed and tightened -
still wont start. I also checked fuse F5 in the fuse box in the front trunk. and pushed all the fuses and relays in just in case there was a loose one. -
Still wont start.
I removed, inspected and returned every existing fuse and relay in the trunk panel. IT STARTED !!!
Message and lesson learned. Just don't push in a fuse, remove completely and reset the fuse and relays.
The great thing is NO tools were required and IF you needed a new fuse, there are spares in the fuse box cover. I hope other newbies like myself find this helpful.
IF you need to reset the battery connections you will need a torx wrench and a flat head screwdriver. I am now starting a collection of must needed tools to keep on the bike other than the standard basic tools like my ratchet Torx.
Good tech tip
Still wont start.
IF you need to reset the battery connections you will need a torx wrench and a flat head screwdriver. I am now starting a collection of must needed tools to keep on the bike for every ride.
Thanks for sharing the tech tip. This one I'll write down in my owners manual that I keep in the trunk.
:thumbup:
Mike
