markjperry
Went for a short drive, picked up a friend as a passenger for 15 minute ride. After the ride I shut off the bike it would not start. Turn the key, full instrument lights and no error. When I pressed the M+ Starter button -
Nothing. Everyone recommends battery terminals. I removed and tightened -
still wont start. I also checked fuse F5 in the fuse box in the front trunk. and pushed all the fuses and relays in just in case there was a loose one. -
Still wont start.
I removed, inspected and returned every existing fuse and relay in the trunk panel. IT STARTED !!!
Message and lesson learned. Just don't push in a fuse, remove completely and reset the fuse and relays.
The great thing is NO tools were required and IF you needed a new fuse, there are spares in the fuse box cover. I hope other newbies like myself find this helpful.
IF you need to reset the battery connections you will need a torx wrench and a flat head screwdriver. I am now starting a collection of must needed tools to keep on the bike other than the standard basic tools like my ratchet Torx.
