2012 RT - Anyone have an idea of the Cost of a New Belt, Installed?
Raknid
Today, I noticed a slight fray of the drive belt on my 2012 Spyder RT. Anyone have a rough idea of the cost for the dealer to replace it?
I'm in Oz, so I doubt a price comparison with what we'd hafta pay here to purchase a new belt and get it fitted would help you all that much... 😣
But seriously, how much actual 'fraying' &/or wear does your belt actually have?? :unsure:
The belts our Spyders run are truly pretty robust and can look pretty ratty while still remaining perfectly functional for many, many more miles! I've seen belts like these on our Spyders that've looked pretty frayed along the edges &/or even had a smallish hole or two punched thru them go on to last another hundred thousand miles or more, so if your belt has just 'a little' fraying on the edge and the teeth on the belt haven't actually started to wear into an oddly deformed 'half moon' shape, then maybe you're worrying prematurely?! ;)
My first question would be, are there any dealers near you who will work on a Spyder over 10 years old, or work on one based on the 998 Rotax V-twin.
As long as the fray isn’t into the meat of the belt, I’d take a razor blade and carefully cut the fray off. I get these on my snowmobile belt occasionally. No problems cutting them off. I have 34k on my Spyder belt, no frays yet for me.
From Copilot:
  • Belt price: OEM BRP belt: $300-$350 (Some dealers mark it up to ~$400)
  • Labor time: 2.5-4.0 hours depending on the tech Typical dealer labor rate: $120-$160/hr Labor cost range: $300-$600
  • Total typical bill: $600-$950 (Higher end if the dealer is slow or insists on full alignment procedure)
I looked on BRP cost for a replacement and for a 2018 RT is ~$400, so the AI estimate seems proper
