2012 rt se5
cabodan
Looking for advise on my 2012 rt se5 I have the BAJA RON and HEIM LINKS installed and had Ann and Joe do the laser and wondering if I need to get the ELKA shocks.While I was in Eureka some say yes and some say don't need.
Personal choice methinks. I have the ronbar and links, balanced tire pressure. Stock shocks and ride it like a sport bike in the twisties.
Changing out shocks isn't even on my wish list until these wear out, they seem to be performing quite well and I can't ask for a better feeling ryde or performance.
Why not just put some miles on your current setup? :dontknow:
Your very own, finely-tuned butt will be able to give you the answer... :D nojoke
Explanation: we can't tell you, what will work best for you.
Try this..!!
do you think you need them..?? Are you having problems handling the corners and back roads. Do you want/need to hit the curves faster..?? Have you tried adjusting the shocks you have..?? Can you justify the expense..?? Have you thought of the pittbull relocator blocks..?? Questions you need to answer because you are the driver of your machine...jmho...just because someone has them and goes around corners faster does not mean if you get them you will go just as fast...:thumbup:
Corners
If you can go around curves/corners fast enough to scare yourself or Peanut then you don't need to get new shocks...
BTW, hi from just south of you guys.... :)
