2013 RT problem
ekfraz
I noticed the plastics on my Spyder are warping from all the heat. I just noticed it today, they have me a new seat on order due to the stitching coming loose, I dont have 2,000 miles yet. 2013 was not a good year for BRP.
There are also some new panels to help remedy the heat situation. Do they have those on order for you? This is a warranty item.
I know that BRP has the air scoop panels for the 2013 ST had them install them on my STL under warranty.
Are they making them for the RT? that would be great if they are cause they sure have made a world of difference on the ST :thumbup:
If it's like this
Here is a picture of the panel from my RT.Panel.jpg Have them check the exhaust gaskets. If you haven't had the master cylinder and evaporator checked make sure they do. My panel was covered under warranty. As mentioned on the thread BRP doesn't have updated panels for the RT's. If they order you a new panel make sure they remember to order new shielding for the backside of the panel cause it doesn't come with it on.
