2016 f3t rear shock
ralph12345678910
Does anyone know where the air adjuster is located for the rear shock, manual says under the passenger seat but I can not find the valve stem anywhere
Rear shock not holding Air 2016 F3-T
I have found it, no air in shock at all, put about 20 lbs in it, thanks for the info
I put 30 lbs. in my rear shock, I noticed it bottoming out on the last ride. I checked it and there was no air in it. Shouldn't it hold the air??
Or is this a defect on my 2016 F3-T.
It should hold air.
It could be just a leaky schraeder valve.
Air it up then do the spit test to check for bubbles.
If they are present use a valve stem tool to tighten up the core.
There are other places for a leak, but that's a good place to start.
