WRCLVR
Hi,
We have a new to us 2019 Can am Spyder RT limited with only 3675 miles. Battery went flat as the charger we had hooked up to it went offline during a power outage. When we tried to start it, the dash gave a <check key-wrong key> message. Now we had left the key in but not turned on during the real cold spell in Atlanta (6*F)
I took the key out and warmed it up in my hand inside the house while browsing for new starter batteries, JIC ... Then I took the key back out the garage and inserted it...the message disappeared and of course the bike then started albeit very slow cranking. ONCE.... I did see 3 codes but did not write them down. Lesson learned there...edited ...got it to go to diagnostic codes P0513 listed
I ran the bike for about 10 miles to charge the battery up. Then hooked up my new Battery tender 1.25a (on battery backup) to keep it charged up. 13.1 volts so good to go. Put the key in and same message (check key wrong key) this time the message wont clear and it won't go forward to the dash to get codes. Nor will it even turn over....
So, anything I can try? Any one local with Buds2 to get into the ECU and see if resetting it will clear everything? I will go get a new battery in the meantime.... although I don't think it is bad.
BTW I have both keys, and both do the same thing so yes, I tried that.... do the keys have batteries in them?
Leaving an email here: [email protected] so that if anyone local in Atlanta has a BUDS2 scanner tool they can get in touch with me...
Thanks,
Milburn
Thanks,
Milburn
