2020 RT 2" Risers
Dray
This bit of info may only apply to the 2020 RT. To install the handle bar Risers it is
necessary to trim a slot on both side of top mounting bracket between the small
ears on both sides. This allows the Riser to slide inside the bar mounting holes
about 1/2". I could have trimmed the slots a little deeper but so far the handle bar
is mounted pretty tight and the top mount does not seem to be have structural damage.
I really expected to receive a better mounting procedure.
Dray
Yep, could have done what Chris did. But after spending all most $100.00 for the
Risers I was not in the mood to chase another part. It would have been nice if the
company would have stated that a couple inches of top bracket needs to be cut off.
May have changed my buying the risers.
Anyway, the risers now fit and do what they are suppose to do.
Dray
Dray, I sent you a pm, I have an F3 top clamp that I will send to you, no charge.
F3 clamp all the way! That's what I used, works without any further modifications, wiring harness is long enough!
A Lady by the name of Connie is sending me a F3 top clamp to replace the one I cut
on. A very generous offer and it is much appreciated. I owe her big time.
Thanks Connie for your generosity.
Dray
Dray, as a new 2020 RTL owner I was not aware of these risers. Could you steer me where I can buy, I need them badly getting a lot of pain across my upper back between and above my shoulder blades.
Doug, another option in addition to the risers is to swap out your handlebar with an F3T or FL handlebar.
Right I work for a dealership part time and we have the F3 \T sitting on our floor but I am not 100 percent sure that is what I need. Plus the cost is double I am in no hurry I am hoping I can get use to the stock bars but I fear that is not going to happen. I am coming off a 2018 Honda GL1800Tour and I needed to put Helibar plates on it. But thank your for mentioning these even though I work at the dealership I have really not paid that much attention to the Can Am but to load them up on a trailer for service or take to a new owner. But it is great getting into something totally different and meeting this community.
Connie, received the F3 clamp and thank you very much. Works beautiful.
I OWE YOU BIG TIME !!!!!!!!
Dray
Doug, did you find out where to get the risers for a 2020 RT? I didn't see an answer to your question. Thanks,
Steve
Yes I did find them however instead I ordered and have them on now a F3 short reach bar. Along with the factory backrest I feel this will do the trick. Thanks for the reply and good luck with yours
Bluejammer I'm contemplating ordering risers fro LaMonster as well. I would appreciate some feedback when you get yours installed.
I just installed Lamonster's riser and I couldn't be happier. I have a 2020 RTS Limited and the stock set up had me stretching a bit to reach the grips. So, I tried short reach bar which moved the grips too close and too high. The riser, with the reinstallation of the stock handlebar, provides a comfortable, more normal configuration.
Still riding. How was the install? I'm mechanically challenged, so I hope it was easy!! Are all the wires long enough to accommodate the riser? Thanks, and glad you like them.
steve
steve
I too am mechanically challenged (physically, too), but being very careful not to strip the bolt heads, all went well. I didn't have to move the wiring because the dealer had already done that when they mounted the short reach bar, which didn't work for me. Someone probably will respond about the wiring.
