2022 Base RT wind swirling behind windscreen - any fixes or advice?
Azbronco
I got my 2022 base RT a couple of weeks ago and just passed 300 miles on it. At high-way speeds (above 65 MPH) the wind goes into a swirling pattern and I actually feel wind pushing/buffeting my back. The first time I jumped on the freeway I was surprised because I've never experienced anything like it in my 20 years of riding (but I've also never had a windscreen this big). I assume the wind screen is creating a pretty large bubble, creating a vacuum effect so the wind is swirling to fill the void. Is there a way to reduce this? I tried putting the wind screen all the way up and it didn't seem to change it--next time I'll try putting it all the way down. Do any of the wind deflectors Can Am sells help reduce this effect? Does the top case on the RTL interrupt the swirling?
Thanks for any tips or advice.
Look up a company by the name of Saeng - they sell a micro edging that I have on my windshield. Their number is 402,563.3444. If they are still around, please pass this on, I am sure you're not the only one feeling this issue.
I watched a video on the science of buffeting on a motorcycle. If a windscreen is too high, the air-pocket vacuum can be moved behind the driver and cause the "being pushed forward" sensation I'm feeling, so I'm going to try lowering the windscreen (raising it while going down the road was the wrong thing to do). It also gave some tips on how to tell if the air deflectors are adding to the buffeting right behind me, and Can Am sells adjustable side wind deflectors if that's the case.
But since we all have different sizes and shapes of bodies, different helmets, different sitting positions, etc--there is no "all you need to do is this" type answer. It seems like it's going to be trial and error, but at least now I know the tips to better determine what's causing it and how to help reduce it.
Use the search function on this forum. There are many threads on this topic, because it is very common.
I went for a ride on the freeway at lunch and resolved it. I played with moving the windscreen in different locations and found a sweet spot where noise was lowest, helmet was in the air-stream (but not the turbulent air), and no wind buffeting on my back.
I found the sweet spot on my '20 RT doesn't noticeably change as speed changes. Pretty much set and forget. Only time I lower it is for slow riding in heat.
