Yes, I did fully charge the lithium battery to the recommended 14.6 volts before installing. I did not bother checking the voltage drop at the battery while cranking - it cranked over significantly faster than the factory battery. My display failures have happened at random times - never at start.
Thanks @Spyderrg. Sounds like I need to visit a different dealer and see if they have any better luck getting BRP to cover things.
I changed the battery as a troubleshooting exercise, just in case it is causing the display “issues”. Lithium will hold its voltage better than lead-acid. Lithium tends to hold “full power” until exhausted. You will need a different charger if your current charger does not have a “Lithium” option.
I might luck out with the battery, but it won’t surprise me if the display is the problem.
Another dealer looking at it shouldn't hurt, altho even 'brand new fully charged batteries' can fail &/or not be able to provide the necessary voltage all the time.
That 'Load test checking of the voltage while starting' thing can reveal quite a few things about a battery, even a brand new fully charged battery, especially if it's not quite up to par - and if they've just come off a charger, they may well still crank faster than the old/replaced battery, at least initially, then drop off later! So while I agree that it's beginning to sound a bit more like it's the display itself &/or the module connectors that are most likely your issue, a 'sub-par battery' issue will not necessarily show up ONLY on starting, it can show up at any time down track, even while riding and even if the alternator looks like it's doing the right thing otherwise!!
So your display dropping out at times other than starting still doesn't exclude your 'brand new fully charged battery' from being less capable than it really should be, but a load test/voltage result while cranking the starter that shows the battery's voltage never drops anything too much below 12 volts should exclude that - and it's usually a very cheap and easy way to check and make doubly sure that it's not the battery after all, especially if you do that test BEFORE you fork out any $$ to take your Spyder to a new dealer and get them to spend time troubleshooting it - again!
So why not just do that test now to make sure you can be sure to be sure?!
Just Sayin'... but it is your Spyder, your time, and your $$ (to possibly waste...)
