2025 F3 - any other way to get software updates? Do I need to go to a dealer?
mini73
Got a safety recall notice in the mail today. Went to try to check for update and it says no updates available. I'm still on v3.1.0 and I did that when I first got the F3 home and checked. That was in Feb 2025. Any other way to get updates? I'm sure there are some. The notice says I need at least V6.0.0 or higher to install. Maybe I have to go to a dealership? TIA
Did you make sure your F3 was connected to your home wi-fi? If so, the update should have been found.
Per other threads on the topic, note that the bike will likely have to be connected to a charger or running for the update to install.
I'm not the least tech savvy and was unsure about trying it at home, so I rode to the dealer. Only took a few minutes.
Sarah
2024 and newer models just need a good wifi connection to download software revisions. Sometimes takes multiple tries to get it to complete.
Not the most tech savvy here. I gave it a try in my garage with the bike running. It was easy to do. Took about15 minutes total.
What everyone above says. If you are having trouble getting wi-fi to connect, make sure your router has a 2.4Ghz wi-fi signal. The bike cannot connect to 5Ghz. Some wi-fi routers that broadcast both 2.4 and 5 can be very difficult for a 2.4 only system to connect to. If that's the case, try opening a 2.4 wi-fi hotspot on your cell phone and connect the bike to it. After the download is complete you may find that the install button stays greyed out. I have done this update on numerous bikes and some are not happy with my battery tender. If that is the case you can get the update button to work by leaving the engine running for the whole time it takes to update. (up to about 10 minutes). Do not interrupt the update process after it starts using either method. The console will blank out and reboot a couple of times. It will tell you when it's finished.
Last week I wanted to see which version of the software I had on my 2025 Canyon. It had been at the dealer several weeks ago and my invoice said that software had been updated. When I tried to connect to my home wifi it asked for the password which I provided and it rejected. I tried several times with the same result. Finally I told it to forget my home wifi. I then went through the process of initializing connection of my home wifi from scratch. Everything worked fine that way and it told me I had version 6.1. You may try disconnecting and reconnecting from your home email.
