Cannot get firmware to update using BUDS3 - any help or suggestions appreciated?!
Jetfixer
Well-known member
I'm trying to update the firmware on a 2025 RT S2S. BUDS3 says there is an available non-mandatory update for the VSS/ABS system. The screen shows that the file is present to be applied, but after checking all the pre-install boxes, the progress window that opens stays on 0% forever. Here's what I've tried so far:
1- Spyder powered up engine not running, on battery tender. (12.8 volts showing)
2- Spyder powered up, engine running, battery tender disconnected. (14.2 volts showing)
3- Tried adding the USB data cable to the USB port in the glovebox (as was required on earlier model console updates) in addition to BUDS3 to diagnostic port.
All no help. Progress box stays at 0%. This bike has the latest console software installed from wi-fi download.
Using BRP BUDS3 1.52.000 (4F6D UPDATE) dated 10-9-2026
Any help or suggestions would be appreciated.
Not knowing BUDS3 but I would suggest looking for an error or transaction log to see if you can get more details.
For what it's worth, pull up Google Gemini and enter the following prompt: "Where are the error logs found on BRP's BUD3 diagnostic system?"
This tells you how to read the BUDS3 error logs, either from within BUD3, or externally from the file store on your PC.
I'd start with looking at this kind of reporting as there may be something useful that shows what is going on behind the scenes as opposed to the UI which seems to be hung.
