2025 F3 Special Series - is there any reason that wiring the heated seat to the unused heated passenger handgrips wiring might not work?
mini73
Bringing this back up since it's starting to get cooler again. I've got a 2025 F3 Special Series, and as we know, it does not have the accessory connection like the models before 2024. When I first bought my 2025 F3, I got an Ultimate seat made for it. I also got the heated model for the front and back seat (Wife wanted it, but so did I) I worked with the guy at Ultimate Seats to try and figure out how to wire the heated portion up but we were not able to find a good way to so, he refunded me for that part of the seat which was very nice of him to do that. I'm wanting to get the heated seat working due to the cooler days coming. I was thinking that since I took the passenger heated grips off to install the the arm rest for the wife, that maybe I could somehow use those, since the plugs are not plugged into anything now. Is there any reason why this might not work? I do not want to butchering the wiring nor do I want to put it in limp mode. Any suggestions or help is appreciated.
A question would be does the system have enough wattage available to actually heat the seat. That stated, both hand holds were heated so maybe there enough wattage. Measure resistance of one hand hold, then multiply by 2 to get total wattage of the OEM load. Here's a link to a wattage calculator that may help: https://calculator.academy/heater-resistance-calculator/. The wire schematics in the shop manuals do not include load information.
The other challange would be temperature control for the seat.
You may be able to find plug and play connectors on Amazon so you don't have to cut into the OEM wire harness.
Otherwise it's just DC electricity.
Thanks, my thoughts also. The seat heaters are like the handles I took off. On or off. On the Ultimate seat, there is a button for the driver and a button for the passenger seat for heat. Maybe one of the plugs can go to the front seat and another to the back seat?
The Spyder has a CANBus system for electricity control and distribution - the CANBus is sensitive to overload from adding lights, air horns, etc. I don't have a wire diagram for a 2025, but in 2023, the rear handle grip heaters were on a 10 amp accessory circuit. The rider and passenger grip heaters, a Rear Fog Light (whatever that is), and a Suspension relay are on the same circuit.
Ok. Yeah this is why I don’t want to just plug or slice the seat heaters into anything.
I would be concerned about the additional load. Seat heaters are going to draw more than the grips. Just upping the fuse is not a good idea. Take wire gauge into consideration as well.
I am, and I'm also sure they have more load. Hopefully I can find something that works. I’m at a loss so far.
I know there is an accessory plug under the front seat of the 2024 F3L. My riding buddy plugged his Ultimate seat into it and it works great. I am hoping to use the same plug on my F3L Special Series also. If it's still there. LOL
For 2024 and up, the output power to the hand grip heaters is NOT simply on and off. There are 5 levels of heat available and it's controlled by the instrument cluster. On 2024 models, the connectors are on the right side behind the fog light. On 2025 and up, the connectors are above the air box behind the left headlight. The connector for the switch next to the ignition is simply a low voltage input to the cluster for controlling the heat level.
Going to look for it today under the seat of my 2025 F3S Special Series. Supposedly, it is for GPS that is not installed. I've got some watertight connectors to plug into it.
Just looked, and it's not there.
I'm talking about the heated passenger grips that were on the back before I took them off to install the arm rests.
It's there. Left side, next to the gas tank, below the seat. You will have to remove the side panel to access it, as its clipped to the frame. Once you find it, it's long enough to relocate it under the instrument panel or handlebars if you wish. It's one of only 2 customer accessory power points on the newer F3. The other one is behind the battery and normally used for the signature light.
Had the panels off and did not see it at all. I did find the one above the 'A' arm on the right side. I have a 2025 F3 Limited.
Finally got the heat connected to the Ultimate seats. Bought a connector with a pigtail protected wire that plugs into the capped off plug above the right front fender. Works as it should.
