2025 F3 Special Series - is there any reason that wiring the heated seat to the unused heated passenger handgrips wiring might not work?
mini73
Bringing this back up since it's starting to get cooler again. I've got a 2025 F3 Special Series, and as we know, it does not have the accessory connection like the models before 2024. When I first bought my 2025 F3, I got an Ultimate seat made for it. I also got the heated model for the front and back seat (Wife wanted it, but so did I) I worked with the guy at Ultimate Seats to try and figure out how to wire the heated portion up but we were not able to find a good way to so, he refunded me for that part of the seat which was very nice of him to do that. I'm wanting to get the heated seat working due to the cooler days coming. I was thinking that since I took the passenger heated grips off to install the the arm rest for the wife, that maybe I could somehow use those, since the plugs are not plugged into anything now. Is there any reason why this might not work? I do not want to butchering the wiring nor do I want to put it in limp mode. Any suggestions or help is appreciated.
A question would be does the system have enough wattage available to actually heat the seat. That stated, both hand holds were heated so maybe there enough wattage. Measure resistance of one hand hold, then multiply by 2 to get total wattage of the OEM load. Here's a link to a wattage calculator that may help: https://calculator.academy/heater-resistance-calculator/. The wire schematics in the shop manuals do not include load information.
The other challange would be temperature control for the seat.
You may be able to find plug and play connectors on Amazon so you don't have to cut into the OEM wire harness.
Otherwise it's just DC electricity.
Thanks, my thoughts also. The seat heaters are like the handles I took off. On or off. On the Ultimate seat, there is a button for the driver and a button for the passenger seat for heat. Maybe one of the plugs can go to the front seat and another to the back seat?
The Spyder has a CANBus system for electricity control and distribution - the CANBus is sensitive to overload from adding lights, air horns, etc. I don't have a wire diagram for a 2025, but in 2023, the rear handle grip heaters were on a 10 amp accessory circuit. The rider and passenger grip heaters, a Rear Fog Light (whatever that is), and a Suspension relay are on the same circuit.
I would be concerned about the additional load. Seat heaters are going to draw more than the grips. Just upping the fuse is not a good idea. Take wire gauge into consideration as well.
Ok. Yeah this is why I don’t want to just plug or slice the seat heaters into anything.
I am, and I'm also sure they have more load. Hopefully I can find something that works. I’m at a loss so far.
I know there is an accessory plug under the front seat of the 2024 F3L. My riding buddy plugged his Ultimate seat into it and it works great. I am hoping to use the same plug on my F3L Special Series also. If it's still there. LOL
