trikermutha
I always loved a good tire thread.
opcorn:
I always loved a good tire thread.opcorn:
Why have you decided " Attacking me personally " proves or bolsters your theories on this subject ???? .... I'm not a " know-it-all " and I resent the inference..... the views I express on tires is based on my Schooling and training in the subject. I have testified in Court about what tires can and can't do based on my knowledge. It's known as " Expert witness testimony " , NOT - " know-it-all testimony ". There are people who THINK they know what they are talking about .....and a couple here who actually KNOW what they are talking about............ Everyone has the right to believe what they want, the problem arises ( for me ) is when they make statements that are Scientifically false, and that information could potentially hurt people ..... I will never argue with anyone who states that red ( or blue - white - yellow etc. ) is the best / nicest color, because it doesn't matter. But tire " PSI " does...... My message is about safety ..... frankly I don't know what your message is ............ Mike :thumbup:
:roflblack::roflblack::roflblack: ..... I have a feeling that you had a distant relative who was at " Kitty Hawk " and EXPERTLY remarked ............. that thing will never fly :lecturef_smilie:........:roflblack::roflblack::roflblack: ..... and PS the world isn't Flat ......and PPS " Butt " theory is as valid as Bar Stool - BS ....... also ....Happy New Year , Mike :thumbup:Hey Mike. I am also as you stated...."an expert witness".
I (we) could not testify that we know better then a tire manufacturer, you would be laughed out of a courtroom if you did.
That testimony would only come from a tire manufacturer.
My statement, albeit harsh, was to demonstrate you are not an expert in that field.
PSI means little if the tread is too hard for the weight of the vehicle.
Adding another slight problem, the Spyder is 2000-3000 lighter then a car AND missing a tire.
That missing tire decreases traction and adding a harder tread is adding greatly to traction loss.
I have 20,000+ miles on my Spyder with the same front tires still going strong.
I am not going to mess with what BRP mandates because some random digits on my screen says BRP is wrong.
I am not going to let anyone I know put the wrong tires on anything that might cause them harm without my 2cents mentioned.
I went as high as 23 PSI and thought that was to much.
I felt better at 19 psi for the Spyder but I am running Federal Formoza on mine.
Never liked the stock tires.
Good luck on this topic. :shocked:
How about 75 psi or even a 100 psi. They float better when crossing rivers with the higher PSI's right? :joke:
Jack
I don't know why I hadn't thought of this earlier. I used to autocross and crew for a road race team. The way we dialed in pressures was by measuring tire temperature with a pyrometer.
You can either buy a probe type pyrometer, or if you have an instant read meat thermometer with a probe, that will also work. There are simple infrared surface thermometers that you can get, but the probe ones IMO work best. Surface temps lose heat too quickly to get a good read. Probes read the temperature inside the tread block, which are more stable without surface cooling playing a factor. Some electrical multimeters come with a temperature probe, too.
Go out on a warm day, and make a good loop with turns or multiple figure eights (equal left & right turns) to warm up the tires. If they feel warm to your bare hand, then there is enough heat to read. Do a few more figure 8's and immediately stop and get some temp readings.
Now, you each may have personal preferences about what pressure works best, and yes overinflating it so that the contact patch gets smaller will increase steering response. But, the optimum grip happens with the full width of the tread on the ground. The way to get that is measuring the tread temperature on the inside, middle, and outside of the tread. You're looking for the tire pressure that results in even temperatures across the tread. Realistically, temps change from the time you make the first reading until you make the last. A spread of 10 degrees C is acceptable. Also, if you make equal numbers of right and left turns, the readings of each tire should be similar. If you make left turns only, the right front is loaded harder and should read higher than the left front tire.
Pressure too high, and the middle temperature reading is the highest. Too low, and the outer edge temperatures are higher than the middle. Assuming you can't adjust camber or toe, playing with tire pressure and tread temperatures might help you dial in your optimum settings.
...The heat measurements were pretty consistent across the surface and corners. The rear tire heats up much more than the fronts.
I think BRP has the crappy Kendas on them because a Spyder is technically a "motorcycle." Motorcycles cannot have "automobile" tires on them. Basically a CYA........
That would make sense for the initial start of the Spyder line, but there are many tires in our sizes. Why has BRP not worked new contracts with real tire manufacturers by now? Heck, the big "rumor" of the 10th anniversary announcement was a new tire option. But, alas, it was a Trans Am paint job. (Which I like!The story I read somewhere was that, when the Spyder was in development, BRP released a request to tire manufacturers to provide OEM tires. The only response they got back was from Kenda, known more for making tires for utility vehicles (off-road quads; forklifts; wheelbarrows; small trailers). I think, at the time, they also had some experience making low-end tires for the western Pacific region (itty bitty cars).
Everyone else likely concluded this was a niche market requiring non-standard sizes, hence not worth the investment. So BRP was stuck with Kenda. If BRP had designed the Spyder to use some slightly larger tires, more in line with what the larger manufacturers already produced, we might not have this problem.
I was running at 19 on my AZ01's and it handled great but I have some injuries that beg to have lighter/less effort steering and I have moved up to 22psi cold. It still handles great but is soooo much easier to bend into the corners. I do feel it being a little more nervous at warp speed on a rough road but until I heal all the way (Please God, make this day come sooner!) the higher pressure is where it is at for me.
no, no, no.. You don't get it.When we first got our first Spyder, I tried the front tires at about 30 psi for a while. I found it to "bounce" and be a bit twitchy and harsh at hwy speeds. It makes sense though....the harder the tire, the more bounce and less road contact. So.....I slowly decreased pressure and have found that 21 psi works well for us. We ride two up most of the time. As for the rear tire, I've kept it at 28 psi the whole time. It's all about what works for YOU.
