Abnormal Things Today
TOPDOGJIM
First I shut the Spyder off, took out the key, came in the house and the radio turned on. Second some kind of multi colored lines appaered in columns (out of no where). Third with the Spyder running the screen went to the one telling me to read the card or hit the mode button. I did and it was fine after that. Is it dealer time?
Jim
If it happens again it sure is. This may not have left a trace, but if you are at the dealer, tell them and let them peek at the diagnostics. If there is no trace, it wll be harder to track.
Sound like something's not wright . Probably won't show a code but I would have the dealer have a look.:dontknow:
It a close encounter of the third kind. do,de,dododo. Did you see any bright lights in the sky. :roflblack::roflblack::roflblack:
Mike
I had exactly the same thing happen, I was about 100 feet away and the radio came on all by it self, with no key in the ignition! I had the lines show up on the screen, the startup message and strange messages appear and then a bit later it went into limp mode off and on. Then it would not start for a while before suddenly clearing up. I ran back to the dealer slowly and they found a loose ground cable (I had about 75 miles on the bike by then. It never has done this again so I believe they knew what they were doing with the repair.
Thanks everyone, as soon as I can get to the dealer, it is going in.
Going into dealer on Thursday afternoon. Going to miss a huge ride scheduled for Sat unless they find something easy and quickly.
Dealer found a few things on the buds, but nothing related to the issue. Of course no one can replicate the problem(s). Rode nice with no codes or funky screens on the hour ride home - sunny and 80 degrees, Life is tough..
You may have been pushing the mode button when you turned the key off. That would make the radio come back on.
