I added prob a pint or a little less maybe of the blue peak brand mix. all I had.
:gaah:....Well you were certainly low on coolant.......However as " Cruzr Joe " just mentioned mixing certain types of Anti-freeze can be very bad........and BRP doesn't use the Common Type ( that figures ) ........Good Luck with what you put in, ....what EXACTLY did it say on the container ?????......Mike :thumbup:
It's the same person who's responsible for the placement of the rear wheel air valve.whoever designed for the location of the coolant reservoir tank ought to be shot! rant off![]()
When I changed my coolant the first time I wrung off the bung. Solution? Purchased new plug, epoxied in place and use the lower hose drain method. You live and learn.I just had my coolant changed by my dealer( High Country Power Sports in SLC). In the course of our conversation he told me that the threaded bung was just jambed in the hole and frequently comes loose when the drain bolt is removed. They had this happen a couple of times and had to remove the radiator and welded up.Their method is to remove the lower hose and drain the coolant that way.
Has anybody else run into this problem
Whatcha got? Year, model, you know, stuff like that.Can anyone explain to me how to access the coolant reservoir
Sent from my SM-G925V using Tapatalk
I have a 2015 RT Limited, and would like to know how to access coolent res reservoir.
