I just installed a trailer hitch and new Kuhmo rear tire on my '15 RT Limited. I removed the lower shock bolt to release the swing arm & belt tension. What I forgot to do was disconnect the link for the self leveling system. When I test code it, I found the air pressure to be maxxed out & will not drop pressure to maintain proper ride & correct height. Any suggestions to correct would be greatly appreciated.
Thank you.
Thank you.
