MMcc
2011 RT- S. Rear air bag loses pressure slowly. Compressor does not work. Only 200 miles on it now. Should I bring it to dealer now or can I wait for the 600 mile service? I will keep checking to make sure there is always 20 psi or more in the bag. Any advice, checked the switch, power is there as it does light up and shows up on the LCD monitor when the switch is pushed but compressor never kicks in. Checked fuse and relay seem to be ok. When I push the switch to lower the pressure setting it quickly drops to zero. Pump it to 60psi, holds for about two days. I did find that the valve core needed to be tighter. Still small leak somewhere.
