Any ideas on Replacing Heated Grips with Non-heated Grips? 2012 RT
solidgranite
My 2012 RT SE5 has heated grips. The grips themselves are worn down and "slick" from age and use. I want to replace the grips, but NOT with heated ones. I don't want to have to take a ton of tupperware off and remove the whole grip heating wiring harness, etc, I just want to change my grips for new ones. The current grips have wires connected/embedded to the inside of them, so it's not just a case of "slip off the old, slip on the new". I don't care about the heat function, but my arthritic hands would appreciate a larger and softer grip surface. Any ideas?
Try a set of Grip Puppies. They slide right over the old grips and are larger and softer. They would also allow you to retain your heated grips. They sell for about $20 bucks on Amazon; Lamonster has them for $14.
johnv
Grip Puppies are good, but I really like these....
Grip Buddies (don't know which one came first) but these really did a great job of making the grip thicker for my hands and they wrap around rather than slide over. I like the texture "grid" feel of the surface.
https://www.originalgripbuddies.com/
Either one will probably do what you want.
I'll second the Grip Buddies in the Lite version. Improved grip, yet the heat still comes through nicely.
johnv
Thanks! I'll visit Lamonster's site and check them out!
I'll check their site, and compare them to Lamonster's version. Thanks!
