Anyone else fitted one of these Handlebar Brake Conversions? Having problems setting it up, need help/advice.
Have you spoken with Martin about the problems you are having?
I have been communicating with Pali @ MTV, they are not sure what the fault is but have contacted the manafacturers. I wondered if someone on here has had the same problem.
He may have a video out there of the installation of the system! Check his blog!
Yes he has a very good fitting video which I followed.
I've also been contemplating the hand brake. So far, almost everyone who has one has had issues with it. The Spyder mechanic I frequent, who has installed them, tells me, "Forget it! It's a waste of time and money. Your OEM foot brake is designed to activate the entire system for a reason. But if you pay me twice what it costs, I'll put one on for you, and I'll almost guarantee you won't be happy with it in the end." I told him when I panic stop, I'm always reaching for that right-hand front brake lever. He said, "Yep, I do exactly the same thing, but it's not going to make you stop any faster." Well... *****! LOL
I got the ISCI brake system... It was worth it.
I have problems with my right hand, unfortunately the ISCI wasn't an option for me.
The MTV brake system works on both the RH & LH side. I have gone for a handlebar brake system because it will make my riding experience so much easier for me.
Hi 2dogs,
Has your mechanic been fitting the MTV handlebar brake conversion? If they don't work, it would be good for me to have precise evidence of this.
Andrew...
Hi 2dogs,
Andrew...
Even if that mechanic hasn't fitted any of those particular hand operated brakes, as a general thing, you simply cannot 'squeeze' with your hand (either hand!) as hard as you can 'stomp' with your foot, and since our Spyders have all this VSS, EBD, ABS, et al stuff, if you REALLY need to stop, stomping as hard as you can with your foot will maximise the Spyder's braking effort and capability, yet still keep the Spyder relatively composed and going in the direction you are pointing it (which is why it's such a good idea to practice looking at WHERE you want to go rather than at WHATEVER you're trying to avoid!!) :rolleyes:
So all else aside (except for those who have physical limitations on moving/applying pressure with their foot/feet) if your Spyder's brakes are functioning as they should, then you'll get the BEST braking capability from your Spyder if you use the foot brake - and I know from some close calls and occasionally painful experiences that there's not much at all (or possibly anything!) out there on the roads that'll stop quicker than a Spyder, IF you stomp on that foot brake! ;)
Of course, it really helps if you're able to use whichever foot (some have swapped the brake pedal to the other side in order to allow them to use their 'good leg'); that you've practiced your 'emergency braking techniques' a bit; and that you know how to and are reasonably competent with using all the VSS, ABS, EBD stuff et al to your best advantage - and equally as importantly, that you've checked your mirrors/behind you recently enough to be aware of anyone following too closely so that you can take evasive action to get out of their way if necessary!! Do you really need to ask me how I know that no matter what the vehicle behind you might be &/or how skilled that vehicle's driver is/how quick their reaction time might be, if you, on your Spyder in front of them, suddenly jump on the picks (with your foot!) and STOP at the Spyder's maximum stopping rate, which is quite astounding to many, there is absofreakinlutely NO WAY on God's Green Earth that pretty much any vehicle following can stop quicker/harder/in a shorter distance than your Spyder - so if the following vehicle/s is/are close, you might also need to EVADE and get outta their way too, even as you continue to brake and evade whatever is in front of you that caused you to need to brake that hard in the first place!! :oops:
Just Sayin' - if your foot works (either foot!), then using a foot to apply the Spyder's properly working OEM brakes will maximise its braking efforts and capabilities. (y)
That's exactly what my mechanic friend was explaining to me. The weight of the spyder (1K lbs) and its braking surfaces compared to those of an average vehicle, the spyder stops faster. Physics 101. The design of the hand brake is primarily for those who may have physical limitations with their right leg or foot. For me anyway, reaching for that front brake lever with my right hand during a panic stop is PREMINENTLY imprinted in my brain, and it will likely NEVER go away. LOL Training oneself to identify and focus on the safest way to avoid an obstacle, rather than focusing on the obstacle itself, takes years of experience to develop, and most operators today don't have, or will never have, the time to attain that ability. I've witnessed more than one rear-end collision, and most could have been avoided simply by attention to distance.
We have a couple exercises in our 3-wheel training where we tell the students to stomp on the brake and feel the engagement of the ABS. The first thing we tell them is to squeeze the "tank" hard with your legs, because we've had students actually break the windshield when they went through it!!
I broke the visor on my full face helmet, split my lip, and almost lost some front teeth (they ached for a week longer than the lip did!) when I smacked the top edge of the windscreen on my first testing of the limits of my 2013 Spyder's (Brembo) braking capability on a braking test bed - and I already knew they'd work really well and was prepared and suitably braced... or so I thought! :eek:
I've been told the 'Stoppy' the Spyder and I did was pretty spectacular, altho I didn't feel that the Spyder's rear tire was all that far off the ground, due to the ABS doing its thing - but apparently all those watching thought it was, at least for such a large machine! And they were very impressed with the extremely short stopping distance, and the Right Footplate's 'drop away' action to allow further pedal travel too. ;)
I use the ISCI setup and the foot brake on a 2020 rt. EBC pads and discs. The originals chattered. casual braking by hand. Both for heavy duty.
Helps me modulate the brakes. Double BKA.
Hi 2dogs,
Andrew...
It will work if properly installed. However, it won't be any better or faster than the OEM foot brake. For "precise evidence," I suggest you purchase one and install it to find out for yourself. Good luck, and let us know how it works out. Remember, there's a considerable difference between functionality and psychological security. If it makes you feel safer and more in control, by all means install one. I would.
When I took my Spyder course, (highly recommended), one of the modules was to get up to speed in the parking lot and then floor the brake pedal! They wanted us to see that the Spyder could take any amount of pressure on the brake, and that it would STOP, and stop fast! It took most of us 5 or 6 times to figure that out!
I wouldn't bother with the brake on the handlebar!
I have the ISCI Setup as well and have been riding with it since 2019 and have had no problems with it while riding, why I use the Handbrake is due to MS and I am unable to use my right foot, have also seen paraplegics use the ISCI set up as well.
What I have learnt my hand is not as strong as my foot, so I keep my distance and yes, it can make a boring ride, but you are safe (especially when pedestrians are involved which can be really 😨).
Make sure the mechanics use good quality brake fluid and actually bleed the handbrake correctly, as I have had brakes that were so spongy after a service that you had to pump them up to stop (that's scary 😱)! I use Martins SPYDER High-Performance Floating Brake Rotors and EBC brake Pads on everything, and yes, it does make a difference from OEM.
Take your time, as I am not rushing to my grave, and yes, when I get the opportunity, I do Hoon.
Last thing, get used to squeezing a tennis ball (it helps with hand strength (y))! Think of trying to stop something that weighs over 600 KGs with your hand, and trying to stop it in hurry, because someone has decided to jump out in front of you or a driver has slammed on the brakes for no apparent reason.
I also was real skeptical about no front brake but surprisingly (I mean really surprisingly) I find the foot brake absolutely fine. I don't miss the hand lever at all. However, I can totally see why some people want (or need) a hand brake.
I’m late to this but I put one on because not every stop needs the full pressure of the foot brake. My right leg and foot do not work properly so without the hand brake sometimes there are no brakes. It works quite well, the handbrake just operates the foot brake.
I adjusted to no handlebar levers fairly quick in the beginning, BUT there were some definite pucker factor events at speed where I couldn't find that non existent brake lever. That'll wake you up quick.
Now the whole riding experience on the Spyder is natural, and I prefer it over 2 wheels.
