Anyone else get this Howling Noise? What's the fix?
FWIW the BMW LT community had a similar noise and they called it the K bike whine, the cure was not to ride at that RPM (42-4300) so it would not make the noise. Personally I like a little cheese with my whine ;).
Sometimes you can over think a thing to death!
Needing earplugs to make a piercing whine attenuate to avoid a headache is one solution I suppose. On the other hand, if this is perfectly normal - as my possibly "gaslighting dealer" is suggesting - how is Can Am successfully selling these vehicles with built in deficiencies?
The dealer, and BRP too, IF the dealer has actually contacted them and got that response from them, is full of it to even suggest this 'harmonic type noise or howl at a certain road speed' is 'normal' - there's literally thousands of Spyder Ryders out there who have never been bothered by any loud &/or intrusive noises at a given speed, and many, many, MANY Spyders that just don't make any intrusive noises like this at any given speed, beyond the engine noise anyway! ;) However, there is quite a bit of discussion on the Forum about noises, harmonic &/or otherwise intrusive noises, at or around a given speed... :confused:
So @Bob from Florida, if you spend some time searching thru the older threads here, you should be able to find earlier discussion on these 'harmonic type noises or howls at a certain road speed' reported and (supposedly) fixed by various means in the years since Spyders first hit the streets. The first 'fix' that I can find being mentioned on the boards here was to put a 'single, pea sized dab of grease in the teeth of the belt' to make the noise go away as you rode... not sure exactly how long that one worked, but still?! 😋 Or maybe the actual 'first fix' was to toss the OEM tires and replace them with better quality a/mkt car tires and run them at about 18 psi (lighter load, lower pressure necessary) - that one scored a win for quite a few on the noise they were experiencing at certain road speeds - my original OEM tires didn't last long enough or work anywhere near adequately for me to get upset about any excessive noise they made at any given speed on our Ozzie roads, but changing them out certainly did reduce the whining noise and complaining that I made all the time I ran them as I complained and bleated about how freakin' appalling they were in all respects, so maybe... :unsure:
Anyhoo, the 'fixes' for these 'harmonic type noises or howls at a certain road speed' things progressed thru changing the tension &/or alignment of the belt; to adding (or taking off 😒) a belt 'tensioner' that's really only a vibration dampener and potential belt destroyer; and the latest discussion I could find that was specifically aimed at this 'harmonic type noise at a certain road speed' was the 'very intrusive wind noise whistle/howl' that was eventually resolved, but ONLY for those who complained and knew about the bulletin from BRP and could convince their dealers to fix it, by swapping the original 'black' front pulley for the replacement 'white' front pulley, but that was pretty much immediately before the 'Front Sprocket Recall' with its 'silvery grey pulley and separate bolt and washer replacements' hit the streets and so, this 'white pulley fix' largely got lost amongst all the ensuing discussion on the Front Pulley Recall!?! 😖
So without hearing or getting any more specifics on your particular noise, @Bob from Florida, it might pay to do some searching (up toward the top right of the page) and reading thru the existing threads on these noises - who knows, your answer may be already posted on the boards here? I'd post a few 'Search Results' pages if I could, but that doesn't work here cos what you see as Search results requires you to enter the keyword/search string, and that means my search results won't display for you; so I'd suggest that you, at least initially, enter your keyword/search string AND check the 'Search titles only' box in order to keep the results to a (hopefully) manageable number of pages, and maybe look at 'White Pulley' first (entering just 'noise' returns about 10+ pages of threads!) - at least some of the people who own 2020+ Spyders that had issues with that wind type harmonic noise have had the noise resolved or at least reduced by replacing their original black pulley with the ceramic(?) coated white pulley, so it's gotta be worth a look, doesn't it?? :unsure:
Good Luck! (y)
@Peter Aawen - thanks for the detailed reply. Some of the things mentioned I have some awareness of from previous web searches.
It actually has a white pulley now.
I will do a deeper dive here and also contact BRP to see if they will confirm some of the cases the dealer did submit, like if the belt actually was replaced, etc.
I can't really see all that clearly from that pic, but I hafta ask, is that actually a 'White' pulley, or the silvery grey pulley with the bolt & washer that was meant to be the fix for the red dust & worn out splines?? :unsure:
I'll happily be corrected, but all the actual 'White' pulley's that were the fix for the 'wind howl/noise' that I've seen have been a fairly vivid white, at least as white as the average page of paper &/or the text on the pic, if not somewhat whiter; and (at least in those pics/on my (small) screen) that pulley looks to be much more like the silvery grey pulleys for the red dust/worn splines recall fix that at least a few people here in Oz complained about 'un-doing the wind howl fix' that the previously fitted white pulleys had actually fixed before they took their Spyders back in for the pulley recall... 😖
The hard part of US, being armchair quarterbacks is that we cannot hear what you are hearing! Don't take my comment as a slam, but some people do worry about the sky falling, and I am somewhat sure you're not one of those. Unfortunately, we as consumers have a very small choice of repair shops that really do their jobs well, and if you find a good one, you're a lucky soul! It sounds like you have a shop that hears what you are hearing but you have to just keep on digging at BRP to get off their tails a do something for you. There is a cause for what you are hearing and if your shop has admitted they hear it that's a plus, keep on digging or dump it! Life's too short for aggravation! Sorry you're having it!! :unsure:
It looks white, but, if I order the Lamonster tensioner I will get a better look with the panels off. Hopefully a part number on the belt will confirm if the belt was replaced with the newer type. Document link I shared with the dealer for belt replacement.
I don't think the part number will help much... You'd hafta check, but I have a vague feeling/recollection that the actual part #'s on the pulleys didn't change (maybe the dates on them did??) but the coating & the bolt/washer/fixings did! :rolleyes:
Still, the colour difference is quite distinctive - I doubt you'll mistake the differences once you see the pulley clearly & in person (pics can be misleading), especially once you've seen all three - the old/original black is quite black unless it's been discoloured by the red rust; the white is a vivid white; and the slivery grey pulley is in no way coloured like either of the others... :sneaky:
Edit: Check out the pic of the White Pulley in post #228 here:
The first pic in that post clearly shows an X stamped on the pulley, which means it is of the back/engine side of the original black pulley, only it's faded and been discoloured by the red dust of death! 😖
There's another pic of the White pulley in post #339 of that thread ^ too. ;)
And there's a pic of the 'Silvery Grey' pulley in post #416 of that same thread - to me, that looks more like the colour of the sprocket in your pic, and I'm just not sure if that 'Silvery Grey' pulley and the associated bolt & washer resolves BOTH the wind whistle/howl, or if that fix is something unique to the White pulley?!? I'd HOPE that installing the White pulley with the revised bolt & washer associated with the Silvery Grey pulley recall would fix both issues, but who knows... :oops:
Finally got around to installing the LaMonster belt tensioner. Got my education on removing side covers in the process! I did not think anything could be more involved than my 2018 Goldwing was, nod to Can Am on cover complexity... On balance, air filters are fast on the Can Am versus 4 hours on the Wing and no valve adjustments either. So, overall - normal service easier. Pictures below showing belt part number matches recall - so, perhaps they did change the belt. Old and new tensioner install locations are different - tensioner wheel in different location on belt for LaMonster. Test ride yesterday of 150 miles - resonance noise still there, most prominent at 48 MPH. Moving your head back towards the passenger area eliminates the sound. Raising the windshield attenuates it somewhat. There seems to be a “focus” node for maximum effect.
Hard to say what actual difference was made changing the tensioner. Driving faster than 70 MPH seemed smoother, but I had not been on the bike for 3 weeks, so memory comparisons always suspect. Quality of part superior - aluminum versus plastic, contact wheel larger diameter, and a real bearing versus sleeve.
I guess the next step is finding a dealership to allow a test ride and see if another random Spyder does the same.
Good luck with the test ride!!! Make sure it's around the same year and model, because it will make a difference. My 2012 RTL sounds completely different than my 2025 S2S, and I don't mean just the difference between the 998 and the 1330 motors, it has different sounds coming from under her skirt! :unsure: Good Luck!
I have the howl on my 2023 RTL at about 50 miles an hour. It's very noticeable wearing a full face helmet, but not noticeable when wearing a half helmet. It must be some sort of harmonic in my helmet.
