TerryTheSpyderRyder
Hello, does anyone know where I can get handlebar risers (hopefully 3-inch or more) for my 2013 RS?
They changed the handlebar design that year, so the earlier riser kits won't fit. Starting in 2013, the handlebars are just stubs at the ends of the center bracket, the throttle cables were replaced by electronic throttle wires, and all wires are encased inside the bracket. This leaves very little slack to install any of the risers for the earlier Spyders. Hopefully someone is making a newer kit, otherwise I will have to do massive rewiring to retrofit an older kit. If a newer kit isn't available, is there another solution to bring the bars up and back a little?
Thanks, Terry :yes:
Thanks, Terry :yes:
		 pps:
pps:
