Anyone recognise this plug?
Purple Guy
I removed my Frunk a couple weeks ago when I was swapping my Fog Lights for LED’s.
When I put “Humpty” back together again I was left with a plug I don’t remember disconnecting and which I can’t seem to find a home for.
Any wisdom from my fellow Spyder Guru’s would be appreciated!
attachment.php
Interesting. ...
There are plugs in the wiring harness for things you may not have. If it is the two pronged one , it looks like it is capped off so it may have been there when you started check and see if everything is working if it is important the spyders nanny will complain and let you know.....:thumbup:
I should have mentioned that the Spyder's running fine and I have checked for codes which there are none.
Seems your good to go...Not that familiar with the RT's and know there are hookups for the fogs, heated grips, gps, sound systems etc. If all is working it must be for something you don't have....Ryde on.....
Sent from my SM-T560NU using Tapatalk
Plug
I seen the same plug on my RTS there was nothing pluged into it.
The large one is for the ECU the smaller one is for the electric frunk release (not used) that are not on the newer spyders.
The white thing is the temp sensor
I think that is for the electronic Frunk solenoid that did not come on 2014's. The harness is there just not the solenoid.
That's my guess.
Bob
