Anyone tried replacing bad foam on inside of tupperware/panels? What's best to use?
steve636
Hello, has anyone replaced the deteriorating foam on the inside of the tupperware panels with replacement foam, or the foam with the aluminum foil? My foam is falling off, was wondering if I should replace it with a foam sound deadening/heat shield, or would it be better to go with a foam with the aluminum foil for sound deadening and maybe better heat shielding? Or any other ideas? Thanks.
I have, and used this along with Air Condition duct silver tape: So far so good: https://a.co/d/0fWzZen (July 2024). I only did the two "knee panels" (the ones under your knees; one of them covers the oil filter).
Note, it is a pain to remove the old stuff! Goo gone and mineral spirits is what I used. Bike does sound different (quieter, or more muffled) now.
I just ordered some, based on your post
Use a little heat to soften the glue. Not too much on the plastic, though.
I have thought about this with the Killmat product I have in the garage.
I think you'll find that helps, but not very much. The foam is disintegrating, so the only thing you can hope to pull on is the very thin plastic backing with the original adhesive on it. In some cases, mine did hold together and would peel up, but mostly, no. YMMV
