Arachnid Tires
Tire matching
Mike, So you are saying that as long as the tires on the front match it don't matter whats on the rear??
Joe
As this applies to Spyders ( and all other vehicles ) this is correct....cars have two axels with tires on each side, the computer systems will make adjustments based on what's on each axel ..... To ask / expect them to adjust side to side is a lot. I'm sure their are vehicles in the plus $200,00 range that are much more sophisticated, but this is the exception rather than the rule. Computer controlled stability today is mind boggling at what they have achieved..... imho .......hope this helps ...... Mike :thumbup:
ARACHNIDS
Arachnids are junk, don’t waste your money on one.
:agree::agree::agree: ......... Considering what's available in the Auto tire market, why buy something that's so inferior ( at possibly higher cost ? ) UNLESS you have no choice !!!! :yikes: ..... But then I would buy the Kenda's , they are slightly better than the Arachnids ( but not by much :roflblack: ) .............. Mike :thumbup:
Arachnjd tires are crap.....
Replaced my Kenda with
Arachnjd and found them to be just as bad..... Had to replace it in a little of 6000 miles..... Changed to car tires and I am much happier, plus auto tires are less expensive...… The tires in the picture are Kendas, that was before I switched to auto tires...​
Checked their website and on it it said...
* Specially designed for wet and dry environment
Is there any other kind?:dontknow:
